Ideas for new features
1. Restore last selection/region.
It will be great if Audacity remembers the last selection/region, so it can be restored if user accidentally clicks and it disappears.
2. In "Transport" menu "Loop Play" to be changed to "Loop Play/Stop" (similar to "Play/Stop").
I offer this because it will be easier to set it up as keyboard shortcut.
3. Adding "Edit > Clip boundaries > Align together" option.
Very useful when user extracts clips from different places of an audio track to another track and needs to align them together so then can easily re-arrange them.
4. Option to save in "View > History" that can be used later as batch script and/or chain.
Re: Ideas for new features
I like the idea, but I don't see a clear way to implement it.vpd wrote:1. Restore last selection/region.
What should happen if, for example, I select from "1 to 2 seconds", then extend the selection to "1 to 3 seconds", then extend the start to zero, then "restore last selection"?
Does it restore to "1 to 2 seconds" or "1 to 3 seconds"?
What if I extend the selection using "shift + left/right cursor" or shrink the region with "Ctrl+Shift+Left/Right cursor"? That would create hundreds of intermediate states as the selection boundary extends or contracts a pixel at a time.
In other words, what would tell Audacity to save a selection as a restorable selection? Currently that can be done manually with "Edit > Region Save" / "Edit >Region Restore", but I don't see how that could be done automatically.
You can use spacebar to stop loop play.vpd wrote:2. In "Transport" menu "Loop Play" to be changed to "Loop Play/Stop" (similar to "Play/Stop").
See "Tracks > Align Tracks > Align Together"vpd wrote:3. Adding "Edit > Clip boundaries > Align together" option.
Again, I like the idea, but I don't see a practical way to implement it.vpd wrote:4. Option to save in "View > History" that can be used later as batch script and/or chain.
What happens if the History includes actions that cannot be used in a Chain?
- Quality Assurance
1 to 3 seconds, if it's simple-minded.steve wrote:I like the idea, but I don't see a clear way to implement it.vpd wrote:1. Restore last selection/region.
Losing the selection can be quite a big deal.
Could Audacity not save the selection on KeyUp, just as presumably it would on MouseUp? KeyUp if possible would IMO be a better solution to saving the selection in the AUTOSAVE recovery file than not autosaving the selection at all.steve wrote:What if I extend the selection using "shift + left/right cursor" or shrink the region with "Ctrl+Shift+Left/Right cursor"? That would create hundreds of intermediate states as the selection boundary extends or contracts a pixel at a time.
Did you mean align clip boundaries together that are in the middle of a track?steve wrote:See "Tracks > Align Tracks > Align Together"vpd wrote:3. Adding "Edit > Clip boundaries > Align together" option.
I'm not saying that it would be impossible, but I think it would be extremely complex to even cover "most" eventualities, especially now that we will also have spectral selection and the possibility of scrub playback changing the selection.Gale Andrews wrote:Could Audacity not save the selection on KeyUp, just as presumably it would on MouseUp? KeyUp if possible would IMO be a better solution to saving the selection in the AUTOSAVE recovery file than not autosaving the selection at all.
It is not the case to say that the selection is not saved at all. The current Undo history saves the selection tied to the track state at the time that the track state is pushed to the Undo history stack. What it doesn't do is to save the selection independently of the track state, which is what I think would be required in order to implement this feature fully, but then we essentially have two "undo stacks", which raises many difficult questions about keeping the stacks synchronised.
- Quality Assurance
It should be completely independent of the Undo Stack so I don't see much of a problem there given we already capture one independent selection/cursor position with "Region Save".steve wrote:I'm not saying that it would be impossible, but I think it would be extremely complex to even cover "most" eventualities, especially now that we will also have spectral selection and the possibility of scrub playback changing the selection.Gale Andrews wrote:Could Audacity not save the selection on KeyUp, just as presumably it would on MouseUp? KeyUp if possible would IMO be a better solution to saving the selection in the AUTOSAVE recovery file than not autosaving the selection at all.
The problem is more in "when to capture". AutoSave (independent of the Undo Stack) could make these "when to capture" decisions. But we now don't let it capture selection changes because it captured every intermediate change when selecting with the keyboard, which made that too slow. I don't think it would be conceptually difficult to have for example a button that set "sel0" and "sel1" back to the last state of Sel0 and Sel1 captured by AutoSave.
It isn't always good to push the selection to the Undo History IMO. Actions pushed to history that cannot change the selection should not capture the selection IMO. If you change the Gain, change the selection, then undo Gain, it is rarely helpful to change the selection back to where it was. That does not happen for Mute/Solo, so why do it with Gain/Pan?
Is it possible to make Audacity remember the selection only once, say, 10 ms after it has been set with the mouse or keyboard? Good old Sound Forge had an option like this called "toggle selection". If you select some audio and accidentally click somewhere and lose it, you can restore it with that option.steve wrote:I like the idea, but I don't see a clear way to implement it.vpd wrote:1. Restore last selection/region.
But if I set spacebar as "Loop Play" shortcut, I'm not able to stop the loop play anymore using spacebar. I need to hit the stop button from transport toolbar (or to set another key as "Play/Stop" shortcut to stop with it).steve wrote:You can use spacebar to stop loop play.vpd wrote:2. In "Transport" menu "Loop Play" to be changed to "Loop Play/Stop" (similar to "Play/Stop").
This aligns all tracks together, not the clip boundaries.steve wrote:See "Tracks > Align Tracks > Align Together"vpd wrote:3. Adding "Edit > Clip boundaries > Align together" option.
Yes!Gale Andrews wrote:Did you mean align clip boundaries together that are in the middle of a track?
Yeah, I agree it's hard to implement it. I just saw that chain actions are limited to effects only, but history remembers what user did in every track of the music project (selection, current track, copy, paste, etc...). It will be great to have an option for some command scripts beyond just the effects that chain option offers.steve wrote:Again, I like the idea, but I don't see a practical way to implement it.vpd wrote:4. Option to save in "View > History" that can be used later as batch script and/or chain.
"Region Save / Restore" is a much simpler concept. It simply takes one snapshot and restores it. Any selection changes between those two events are irrelevant / ignored.Gale Andrews wrote:It should be completely independent of the Undo Stack so I don't see much of a problem there given we already capture one independent selection/cursor position with "Region Save".
"When to capture" is, as you say, the major difficulty. There are many ways that the selection may change. To provide a robust "Restore last selection/region" option, all of those cases need to be handled.
An example, looking at the selection setting events:
- Generate a 30 second sound.
Selection start = 0, Selection end = 30 - Click on the waveform at 5 seconds
Selection start = 5, Selection end = 5 - Press Ctrl+i (split track)
- Click on the waveform at 15 seconds
Selection start = 15, Selection end = 15 - Press Ctrl+i (split track)
- Double click on the waveform at 10 seconds
Selection start = 10, Selection end = 10
Selection start = 5, Selection end = 15 - "Restore last selection/region"
We could provide a special rule to handle this specific case, but that is not a workable solution because we can't anticipate every possible combination of events that could happen. What we would need is a general method that will work for all cases, and therein lies the difficulty.
- Quality Assurance
A timer is definitely an option, but it could slow Audacity down if it captured the selection often enough that you would (probably) get the selection back that you wanted. I did not mention it for that reason. Capturing when the selection changes would be much more efficient.vpd wrote:Is it possible to make Audacity remember the selection only once, say, 10 ms after it has been set with the mouse or keyboard? Good old Sound Forge had an option like this called "toggle selection". If you select some audio and accidentally click somewhere and lose it, you can restore it with that option.steve wrote:I like the idea, but I don't see a clear way to implement it.vpd wrote:1. Restore last selection/region.
Did the SoundForge feature definitely work on a timer?
I think Steve meant to set a custom shortcut for Loop Play if you need to (but not SPACE) and then use SPACE to stop normal play and Loop Play.vpd wrote:But if I set spacebar as "Loop Play" shortcut, I'm not able to stop the loop play anymore using spacebar. I need to hit the stop button from transport toolbar (or to set another key as "Play/Stop" shortcut to stop with it).steve wrote:You can use spacebar to stop loop play.vpd wrote:2. In "Transport" menu "Loop Play" to be changed to "Loop Play/Stop" (similar to "Play/Stop").
OK I made a note of your suggestion.vpd wrote:This aligns all tracks together, not the clip boundaries.steve wrote:See "Tracks > Align Tracks > Align Together"vpd wrote:3. Adding "Edit > Clip boundaries > Align together" option.Yes!Gale Andrews wrote:Did you mean align clip boundaries together that are in the middle of a track?
Are there any examples of non-effects that you would want to apply as a macro?vpd wrote:Yeah, I agree it's hard to implement it. I just saw that chain actions are limited to effects only, but history remembers what user did in every track of the music project (selection, current track, copy, paste, etc...). It will be great to have an option for some command scripts beyond just the effects that chain option offers.steve wrote:Again, I like the idea, but I don't see a practical way to implement it.vpd wrote:4. Option to save in "View > History" that can be used later as batch script and/or chain.
If not, Audacity knows what items in the History are effects that can be added to Chains and could export only those.
However History does not capture effect parameters in all cases, without which the feature might be of limited use.
Capturing when changes occured sounds legit. I guess SoundForge did it with a timer, because (like Steve said) we often need to expand or shorten the selection before we get what we want. SoundForge captured and restored only the very last selection.Gale Andrews wrote:Capturing when the selection changes would be much more efficient.
I agree, but what's the point to set a different keyboard shortcut just to stop the Loop Play? Why don't trigger it with just one key?Gale Andrews wrote:I think Steve meant to set a custom shortcut for Loop Play if you need to (but not SPACE) and then use SPACE to stop normal play and Loop Play.
Thank you!Gale Andrews wrote:OK I made a note of your suggestion.
I thought about some simple actions (requiring no parameters) like: paste; duplicate; add new track; move focus: to next track, to previous track; move cursor: to selection start, to selection end, to track start, to track end; go to: selection start, to selection end; clip boundaries: split.Gale Andrews wrote:Are there any examples of non-effects that you would want to apply as a macro?
Didn't know that...Gale Andrews wrote:If not, Audacity knows what items in the History are effects that can be added to Chains and could export only those. However History does not capture effect parameters in all cases, without which the feature might be of limited use.
- Quality Assurance
We can always record the "vote" but I'm not sure it's a good idea. Do you only loop play, never standard play?vpd wrote:I agree, but what's the point to set a different keyboard shortcut just to stop the Loop Play? Why don't trigger it with just one key?Gale Andrews wrote:I think Steve meant to set a custom shortcut for Loop Play if you need to (but not SPACE) and then use SPACE to stop normal play and Loop Play.
I would say what not stop any type of playback with just one key? We don't have two Stop buttons.
None of that would work as of now with Chains applied to imported files.vpd wrote:I thought about some simple actions (requiring no parameters) like: paste; duplicate; add new track; move focus: to next track, to previous track; move cursor: to selection start, to selection end, to track start, to track end; go to: selection start, to selection end; clip boundaries: split.Gale Andrews wrote:Are there any examples of non-effects that you would want to apply as a macro?
