I have noticed that the "Show Clipping" feature highlights every single sample above a value of 0dB or 1 (magnitude) with a red line.
I'm of the opinion that clipping is only significantly important when it comes to multiple samples adjacent to each other that meet the criteria above; 1 sample on its own is unlikely to cause audible distortion, whereas 2 or more are, as they then begin to form the usually unwanted square-wave.
Additionally, when there's a lot of clipping, the waveform becomes buried in red.
If at all possible, I would please like:
- • the option to "Show Serial Clipping", showing lines (white where clipping begins, red where it ends) only where at least one 'clipped' sample follows another.
• the option to modify the opacity of the lines shown
Thank you
