Audacity getting confused about compressed projects?
This read-only archive contains discussions from the Adding Feature forum.
New feature request may be posted to the Adding Feature forum.
Technical support is available via the Help forum.
Tid
Re: Allowing 'Compressed only' projects
Post by Tid » Tue Aug 05, 2014 6:31 pm
steve wrote: Compare these two files. One is a first generation Ogg file with quality setting 5. The other is a 7th generation file with quality setting 5 (each time).
Interesting. There's noticeable 'phasing' on the 7th generation, which is NOT what you get normally when you recompress an AAC or MP3. I have to admit though, I'm not familiar with the Ogg Vorbis algorithm, nor with the way Audacity applies it.
Tid
Post by Tid » Tue Aug 05, 2014 6:37 pm
Gale Andrews wrote: So the objective is to have two versions of each song project you which you can easily open to see the waveforms: 1) containing the two comparison tracks 2) containing the single track mixed down from both? And 1) is a compressed copy of a project?
I think that will work well, but you should close projects before copying them manually or Audacity may complain about orphan block files (files for the Undo/Redo mechanism) when you reopen the copied project.
But you will still get the PCM data in the compressed project once you open it.
More or less - the mixed down AAC is just to play people without necessarily having Audacity open; I can use the Mac's Preview software to play them. The Ogg Vorbis files are there only to see the waveforms in Audacity (and perhaps make a slight adjustment to Tempo or how well they synchronise).
As for the PCM data, I simply delete it (and all other copied data if I haven't made any changes) when I close the 'copy' project.
If I was using Audacity to write my own songs or otherwise create original music I would of course use it differently, and be unbothered about large project files and more concerned about audio quality.
Tid
Post by Tid » Tue Aug 05, 2014 6:43 pm
Gale Andrews wrote:If we went for behaviour 2) then I think it would be desirable to give compressed projects a separate extension to distinguish them from AUP.
Sounds cool. .ACP perhaps (if not used elsewhere?)
waxcylinder
Post by waxcylinder » Thu Sep 25, 2014 4:43 pm
I note that since Gale's last summary post, no voting has been requested.
So just what do we do with this thread? Just archive it?
Peter.
Post by Gale Andrews » Thu Sep 25, 2014 10:56 pm
waxcylinder wrote:I note that since Gale's last summary post, no voting has been requested.
I have captured the votes/behaviours noted here, so I've archived it.
