Gale Andrews wrote:Tid wrote:Audacity 2.0.3
Mac OS X 10.6.8
I've only recently discovered the option to Save Project As A Compressed Version...
Audacity supplied by us doesn't have that (it's Save Compressed Copy of Project). If it really says what you quoted you have an unofficial version of Audacity and we can't help you with that. I recommend you get the latest 2.0.5 from us:
http://audacityteam.org/download/mac .
Sorry - my mistake; I was paraphrasing the option as I hadn't bothered to open Audacity and look at the exact wording.
Gale Andrews wrote:Tid wrote:The problem is when I open that project again. Whether I make any changes, or simply play the project, Audacity seems to ignore the fact that it's just opened a Compressed project (though I can see it physically open the 2 Ogg Vorbis tracks) - when I close it and go to the project data folder, I see that as well as the 2 Ogg Vorbis files, there is now a subfolder of all the many small full size Audacity "pieces", in other words the very data I tried to avoid when I first created the project.
Correct. The OGG files are decompressed to lossless PCM (maintaining but not improving their quality) when you reopen the compressed project. The OGG files thus become superfluous to the project which then functions essentially as a standard project with Undo and Redo as if you had launched Audacity and imported OGG files into it.
The reason is simple, that OGG is lossy and you cannot perform complex direct editing on it such as applying Equalisation or other filters. The audio has to be decompressed to PCM.
Yes, but the original imported data was lossy MP3. I had already accepted further compression to Ogg Vorbis, so I'd resigned myself to having a 'lossy' project (if I was interested in top quality audio, I wouldn't have used the Ogg Vorbis option to begin with!)
Gale Andrews wrote:Tid wrote: OVERWRITE the Ogg Vorbis tracks if there have been changes
You can do that if you Save Compressed Copy of Project and overwrite the original compressed project. The OGG file(s) will be updated (overwritten). There will still be lossless PCM data in the "e*" folder(s).
Perhaps there should be an option to delete the PCM data when saving the reopened compressed project. Perhaps what we should really do is store unsaved changes for the compressed project in the Audacity temp folder instead of in the _data folder for the compressed project. Do you want to request that?
YES! What Audacity ought to allow for, is the creation of an overwritable version of a compressed project, especially if there is no PCM data present - in other words, where the user has deliberately created ONLY a compressed copy, it ought to be assumed that a full version wasn't wanted. But if the option
Save Project as Uncompressed was added to the File menu, then a user who's created a compressed project could - if they chose - add the PCM data to the _data folder, as is being done unbidden at present.
Gale Andrews wrote:Or perhaps Audacity should at least delete the PCM data in the _data folder of the compressed project when you quit the project window that is holding the compressed project. As it is now, if you reopen a compressed project, make an edit, save and overwrite the compressed project, then reopen the compressed project again, there will be "orphan block files" that were for undo/redo the last time the project was open. I agree that is confusing and unsatisfactory.
Yes - even if I simply OPEN a compressed project then close
without any editing, Audacity still creates the PCM data. So now, if I want to re-open a compressed project, I have to manually delete the PCM data. Then
next time I open the project - even though the Ogg Vorbis files are still there - Audacity comes up with a message about not being able to find the data (which it found perfectly well the first time I re-opened it, by reading the Ogg Vorbis files in!!!) and offering options that include making 'silent' tracks. At that point, my head in a complete spin, all I can do is to create the project all over again from scratch, by deleting the .aup file, the _data folder, reading in the MP3 files, making the necessary edits, and saving as a Compressed Project. I can't be doing that every time I just want to look at waveforms and nothing else!!!
