I agree with your criticism of that - it's too like mix and render. I'm just talking about a common sense vertical movement of tracks, where a "Swap Channels" item in the Track Drop-Down would do the same thing.steve wrote:I've just described what I think is the more logical "choice" if we say that "Make Stereo Track" takes account of the channel allocation.Gale Andrews wrote:it does what it does now, because there is no choice but to reverse one of the channels.![]()
So they still sound the same when you make them stereo (because, for example you now want to apply edits to selections in both channels without giving yourself RSI).steve wrote:A practical point: What is the use case for having a mono track set to the right channel above a mono track set to the left channel and wanting to make them into a stereo track with the (upper) right channel moving below the (lower) left channel to create the stereo track?
As Robert says, a way to get at the separate channels without splitting the stereo track would help a lot here.
