Gale Andrews wrote:If it even had a button (as well as the menu item) - for example in the Label Track Control Panel - I would be much happier with it.
I'm not sure what you're getting at. What would the button do?
Gale Andrews wrote:I still think this is another menu item for a "pro tem"
I don't see it as "pro tempore", but rather as "a start".
If we have this menu item then it may be worth also adding "Copy Selected Labels" and "Paste Selected Label".
It may then be worth splitting them off into a sub-menu of their own, which would make selected label operations easier to find.
IF we start using right click menus, then the "selected label operations" could perhaps be moved from the Edit menu into a right click menu when labels are selected.
Or we could just kill the idea before it sees the light of day
Gale Andrews wrote:I can definitely see a user doing that, but that is not how label deletion works via Edit > Remove Audio or Labels, because that menu works on selections (like most of Edit Menu).
The naive user will probably not see the distinction that you are making.
They selected a label, and expected the "selected" label to be deleted, not the entire (not selected) project.
Gale Andrews wrote:In the image below we want to delete labels "er" and "34343" but not "short", "545" or overlap, and we don't want to modify the containing label "mas".
How we would do that with the proposed patch:
- Select the "er" label
- Shift+ Delete
- Select the "34343" label
- Shift+ Delete
How we would do it now without the patch:
- Delete or backspace (depending on exactly where the text cursor is)
- Delete
- Delete
Gale Andrews wrote:Surely what we want (as I have said many times) is multiple label selection?
If we ever get multiple label selection, then my proposal will be even better.
- Select the "er" label and the "34343" label
- Shift+ Delete
and there's no risk of accidentally deleting audio at the same time.
Gale Andrews wrote:But you still have to wander into a cascading menu to find what the shortcut is
Yes, but it is a lot more discoverable than now:
The current version gives little indication that "Split Delete" can be used to remove a label:
- Current version
- current.png (92.93 KiB) Viewed 1468 times
The patched version is a lot more obvious:
- Patched version
- patched.png (63.93 KiB) Viewed 1468 times
Gale Andrews wrote:I don't see in what way right-click (context key) is inaccessible.
Yes, the context key could be used (I keep forgetting about that because I never use it
Gale Andrews wrote:I don't see in what way your solution is accessible, given the label track itself is inaccessible. The labels are not read out, so although you can read the selection from Selection Toolbar, you have no idea what labels are included in the selection without going into Labels Editor.
Labels are certainly less functional for visually impaired users. I don't know to what extent they are used, but you can tab into them, then Enter, then Space to play.
With the proposed patch, you could then remove the label after playing it with Shift+Delete, rather than needing to tab over to it again (from the first tab) to delete it. ("Split Delete" will delete any selected audio and may leave point labels at each end. "Remove selected Labels" will do neither of these unwanted actions).
So far, Ed and myself are strongly in favour of this proposal. Ed has said that he finds this functionality "indispensable".
A while ago I was working on a number of complex multi-track projects, with lots of editing and lots of labels indicating where various parts were - I wish we had this functionality back then.
Split Delete/Split Cut were designed for editing audio tracks - they can sometimes be used to remove labels, but they are not an adequate substitute for a function that has been designed to do the job. It is really irritating to be in the flow of an editing job and then to get held up by "
Can I remove this label like this... No that moves other labels... like this? .... no that deletes the audio as well... like this?... no that changes that label...
" when all you actually want to do is to remove that darned label, which would be so simple if only there was a "Remove Label" option.
I would definitely like to hear opinions from other users that have tried it - is anyone able and willing to build binaries for Windows and/or Mac with this feature?
Here is the patch that is needed to build Audacity with this feature:
