Yes, I'd be quite happy with a two-button (this pane/all) solution if it were implemented that way. But I'd also be happy with a new Reset pane.Gale Andrews wrote:Do you support that idea, if it's ambiguous? I'm -1. I think that idea is complex and could limit the chance of acceptance. I can only see it working if each pane had two buttons, one to reset that Pane's prefs, and a button to reset all Prefs (however defined).waxcylinder wrote:Because if you read the Proposal one if the original (and still existing ideas) is to implement Preferences reset through Edit>Preferences with each pane having a Reset button (which could wither reset the Prefs on that pane or all Prefs - the proposal was/is ambiguous).Gale Andrews wrote: So I don't understand why you say that resetting Preferences would not reset the toolbars.
Best chance of acceptance BTW is to get a patch that can be submitted and tested ...
No it is not my proposal (or intention) to move View>Toolbars into Preferences (though I can see that could be an option). But now you're making me think about this some more, maybe what we need is a "Reset" entry in the Toolbars dropdown menu to reset all the Toolbars to "factory settings". I could get to like that idea and I'm sure it would be more acceptable than moving Toolbars into Prefs (and avoid a regression).Gale Andrews wrote:So is your proposal to move View > Toolbars into Preferences? Or to add a "Reset Toolbars" button into every Preferences pane? That would mean three buttons if we had a choice to reset just an individual preferences pane. I don't see the point of a "Reset Toolbars" button because I think Prefs should have a "sledgehammer" button.waxcylinder wrote:There is nothing in Edit>Preferences to reset Toolbars - hence my extension of James' idea of having a new "Reset" pane in Preferences enabling the user to choose any or all and to include a Toolbars reset.
Update: Oh golly gosh - silly me. - I've just looked at the View>Toolbar menu and seen that we already have such a command
I may need to do some pruning adjustments to that proposal ...
Good.Gale Andrews wrote:There has to be the sledgehammer (outside the Audacity GUI) for the case when Audacity won't launch. And I think for ease of access there should be a sledgehammer button in Audacity.
Peter.
