VST Instrument plugins
This read-only archive contains discussions from the Adding Feature forum.
New feature request may be posted to the Adding Feature forum.
Technical support is available via the Help forum.
somewhiteguy
Post by somewhiteguy » Wed Oct 20, 2010 6:10 am
Just wondering if any future versions of audacity are going to support instrument plugins. Thanks
Re: VST Instrument plugins
Post by steve » Wed Oct 20, 2010 12:18 pm
I've moved this topic to the "Adding Features" section.
I very much doubt that VSTi support will be added in the short or medium term (if ever). Audacity is not a "real-time" processing application - the only real-time thing that it does is play and record. To support VSTi would probably require a total rewrite of the core code and a paradigm shift in the way that Audacity works.
However, I'm aware that MIDI support is currently being developed, though I've no details about this. When Audacity is able to play and record MIDI data it should be possible to use Audacity in conjunction with a VSTi host application (use MIDI to play instruments in another host program).
somewhiteguy
Post by somewhiteguy » Fri Oct 22, 2010 10:47 am
Thanks for the fast reply! Out of curiosity what are the names of some of the programs that could host those plugins? And is it complicated to a computer illiterate person like myself to get them working together with audacity lol. Thanks
Post by steve » Fri Oct 22, 2010 1:41 pm
Audacity does not currently have MIDI support - it's being developed in the experimental branch but it's not done yet.
You may want to look at Reaper, Sonar, Cubase. There are many others, but these are the big names. Reaper has a particularly good trial version and very fair pricing.
roscoe45
Post by roscoe45 » Fri Oct 29, 2010 5:35 pm
On the download frequently asked questions page there is a vst setup...i ran it it installs to program files but when i open program files it doesn't show up does anyone happen to know anything about this? I have a lot of VST software which would be nice to add into the effects tab as the download page suggests it should.....hmmm?????? EMAIL russellferguson <at> live <dot> ca if you can please help with this....tks.
Reason: email address disguised to thwart spammers
Trebor
Post by Trebor » Mon Nov 29, 2010 3:34 pm
roscoe45 wrote:... I have a lot of VST software which would be nice to add into the effects tab as the download page suggests it should
After installing the VST plugin(s) into the Audacity plugin folder you should tick "Rescan VST effects next time Audacity is started",
in "Preferences" ("ctrl" + "p"), “effects“. Only then do the VST effect(s) you’ve added appear on the “Effect” drop-down menu.
Illustration here ... http://forum.audacityteam.org/viewtopic ... 964#p73964
