Additions: log(f) axis in spectrum display; log Tongen
This read-only archive contains discussions from the Adding Feature forum.
New feature request may be posted to the Adding Feature forum.
Technical support is available via the Help forum.
amicheler
Post by amicheler » Tue Nov 06, 2007 2:37 am
Hi,
I have tinkered a bit with the audacity source code:
I wrote a spectrum display with log frequency axis,
and integrated the hidden feature of a log sweep in the tone generator.
I hope someone checks this in...!
Thanks,
Andreas
Here's the patch against the CVS files:
Code: Select all
Index: Printing.cpp
RCS file: /cvsroot/audacity/audacity-src/src/Printing.cpp,v
retrieving revision 1.2
diff -u -r1.2 Printing.cpp
--- Printing.cpp	15 Jun 2006 14:26:13 -0000	1.2
+++ Printing.cpp	4 Nov 2007 23:45:48 -0000
@@ -108,10 +108,13 @@
                                 &viewInfo, false, false, false, true, false);
             break;
          case WaveTrack::SpectrumDisplay:
-            artist.DrawSpectrum((WaveTrack *)n, *dc, r, &viewInfo, false);
+            artist.DrawSpectrum((WaveTrack *)n, *dc, r, &viewInfo, false, false);
+            break;
+         case WaveTrack::SpectrumLogDisplay:
+            artist.DrawSpectrum((WaveTrack *)n, *dc, r, &viewInfo, false, true);
             break;
          case WaveTrack::PitchDisplay:
-            artist.DrawSpectrum((WaveTrack *)n, *dc, r, &viewInfo, true);
+            artist.DrawSpectrum((WaveTrack *)n, *dc, r, &viewInfo, true, false);
             break;
          break;
Index: TrackArtist.cpp
RCS file: /cvsroot/audacity/audacity-src/src/TrackArtist.cpp,v
retrieving revision 1.104
diff -u -r1.104 TrackArtist.cpp
--- TrackArtist.cpp	28 Oct 2007 20:45:15 -0000	1.104
+++ TrackArtist.cpp	6 Nov 2007 02:11:58 -0000
@@ -236,10 +236,13 @@
                             drawEnvelope,  drawSamples, drawSliders, true, muted);
                break;
-               DrawSpectrum((WaveTrack *)t, dc, rr, viewInfo, false);
+               DrawSpectrum((WaveTrack *)t, dc, rr, viewInfo, false, false);
+               break;
+               DrawSpectrum((WaveTrack *)t, dc, rr, viewInfo, false, true);
                break;
-               DrawSpectrum((WaveTrack *)t, dc, rr, viewInfo, true);
+               DrawSpectrum((WaveTrack *)t, dc, rr, viewInfo, true, false);
                break;
             break;              // case Wave
@@ -331,22 +334,22 @@
    if (t->GetKind() == Track::Wave
-       && ((WaveTrack *) t)->GetDisplay() == WaveTrack::SpectrumDisplay) {
-      // Spectrum
+       && ((WaveTrack *) t)->GetDisplay() == WaveTrack::SpectrumDisplay)
+	{  // Spectrum
       if (r.height < 60)
          return;
+		bool logF = ((WaveTrack *) t)->GetDisplay() == WaveTrack::SpectrumLogDisplay;
       double rate = ((WaveTrack *) t)->GetRate();
       int freq = lrint(rate/2.);
-      int maxFreq = gPrefs->Read(wxT("/Spectrum/MaxFreq"), freq);
-      if(maxFreq > freq)
-         maxFreq = freq;
+		int maxFreq = gPrefs->Read(wxT("/Spectrum/MaxFreq"), freq);
+		if(maxFreq > freq)
+			maxFreq = freq;
       int minFreq = gPrefs->Read(wxT("/Spectrum/MinFreq"), 0L);
-      if(minFreq < 0) {
-         minFreq = 0;
-         gPrefs->Write(wxT("/Spectrum/MinFreq"), 0L);
+	   if(minFreq < 0) {
+	      minFreq = 0;
+		   gPrefs->Write(wxT("/Spectrum/MinFreq"), 0L);
          draw the ruler
          we will use Hz if maxFreq is < 2000, otherwise we represent kHz,
@@ -368,6 +371,35 @@
       vruler->Draw(*dc);
+   if (t->GetKind() == Track::Wave
+   && ((WaveTrack *) t)->GetDisplay() == WaveTrack::SpectrumLogDisplay)
+	{  // SpectrumLog
+      if (r.height < 10)
+         return;
+      double rate = ((WaveTrack *) t)->GetRate();
+      int freq = lrint(rate/2.);
+		int maxFreq = gPrefs->Read(wxT("/SpectrumLog/MaxFreq"), freq);
+			maxFreq = freq;
+      int minFreq = gPrefs->Read(wxT("/SpectrumLog/MinFreq"), freq/1000.0);
+	   if(minFreq < 1) {
+	      minFreq = 1;
+		   gPrefs->Write(wxT("/SpectrumLog/MinFreq"), 1L);
+         draw the ruler
+         we will use Hz if maxFreq is < 2000, otherwise we represent kHz,
+         and append to the numbers a "k"
+      vruler->SetBounds(r.x, r.y+1, r.x + r.width, r.y + r.height-1);
+      vruler->SetOrientation(wxVERTICAL);
+      vruler->SetFormat(Ruler::IntFormat);
+      vruler->SetLabelEdges(true);
+      vruler->SetRange(maxFreq, minFreq);
+      vruler->SetUnits(wxT(""));
+		vruler->SetLog(true);
+      vruler->Draw(*dc);
        && ((WaveTrack *) t)->GetDisplay() == WaveTrack::PitchDisplay) {
@@ -1315,7 +1347,7 @@
 void TrackArtist::DrawSpectrum(WaveTrack *track,
                                wxDC & dc, wxRect & r,
-                               ViewInfo * viewInfo, bool autocorrelation)
+                               ViewInfo * viewInfo, bool autocorrelation, bool logF)
    // MM: Draw background. We should optimize that a bit more.
    dc.SetPen(*wxTRANSPARENT_PEN);
@@ -1336,12 +1368,12 @@
    for (WaveClipList::Node* it=track->GetClipIterator(); it; it=it->GetNext())
-      DrawClipSpectrum(track, it->GetData(), dc, r, viewInfo, autocorrelation);
+      DrawClipSpectrum(track, it->GetData(), dc, r, viewInfo, autocorrelation, logF);
 void TrackArtist::DrawClipSpectrum(WaveTrack* track, WaveClip *clip,
    double h = viewInfo->h;
    double pps = viewInfo->zoom;
@@ -1457,14 +1489,27 @@
    bool isGrayscale = false;
    gPrefs->Read(wxT("/Spectrum/Grayscale"), &isGrayscale, false);
    int ifreq = lrint(rate/2);
-   int maxFreq = gPrefs->Read(wxT("/Spectrum/MaxFreq"), ifreq);
+   int maxFreq;
+	if (!logF)
+		maxFreq = gPrefs->Read(wxT("/Spectrum/MaxFreq"), ifreq);
+	else
+		maxFreq = gPrefs->Read(wxT("/SpectrumLog/MaxFreq"), ifreq);
    if(maxFreq > ifreq)
       maxFreq = ifreq;
-   int minFreq = gPrefs->Read(wxT("/Spectrum/MinFreq"), 0L);
-   if(minFreq < 0) {
-      minFreq = 0;
+	int minFreq;
+	if (!logF)
+	{	minFreq = gPrefs->Read(wxT("/Spectrum/MinFreq"), 0L);
+	   if(minFreq < 0) {
+	      minFreq = 0;
+	}else
+	{	minFreq = gPrefs->Read(wxT("/SpectrumLog/MinFreq"), ifreq/1000.0);
+	   if(minFreq < 1) {
+	      minFreq = ifreq/1000.0;
+	      gPrefs->Write(wxT("/SpectrumLog/MinFreq"), ifreq/1000.0);
    bool usePxCache = false;
    if( !updated && clip->mSpecPxCache->valid && (clip->mSpecPxCache->len == mid.height * mid.width) ) {
@@ -1483,57 +1528,119 @@
    int x = 0;
    sampleCount w1 = (sampleCount) ((t0*rate + x *rate *tstep) + .5);
-   while (x < mid.width) {
+	while (x < mid.width) {
       sampleCount w0 = w1;
       w1 = (sampleCount) ((t0*rate + (x+1) *rate *tstep) + .5);
-      for (int yy = 0; yy < mid.height; yy++) {
-         bool selflag = (ssel0 <= w0 && w1 < ssel1);
-         unsigned char rv, gv, bv;
-         float value;
-         if(!usePxCache) {
-            float bin0 = float (yy) * binPerPx + minSamples;
-            float bin1 = float (yy + 1) * binPerPx + minSamples;
-            if (int (bin1) == int (bin0))
-               value = freq[half * x + int (bin0)];
-            else {
-               float binwidth= bin1 - bin0;
-               value = freq[half * x + int (bin0)] * (1.f - bin0 + (int)bin0);
-               bin0 = 1 + int (bin0);
-               while (bin0 < int (bin1)) {
-                  value += freq[half * x + int (bin0)];
-                  bin0 += 1.0;
-               value += freq[half * x + int (bin1)] * (bin1 - int (bin1));
-               value /= binwidth;
-            if (!autocorrelation) {
-               // Last step converts dB to a 0.0-1.0 range
-               value = (value + 80.0) / 80.0;
-            if (value > 1.0)
-               value = float(1.0);
-            if (value < 0.0)
-               value = float(0.0);
-            clip->mSpecPxCache->values[x * mid.height + yy] = value;
-         else
-            value = clip->mSpecPxCache->values[x * mid.height + yy];
-         GetColorGradient(value, selflag, isGrayscale, &rv, &gv, &bv);
-         int px = ((mid.height - 1 - yy) * mid.width + x) * 3;
-         data[px++] = rv;
-         data[px++] = gv;
-         data[px] = bv;
+		if (!logF)
+		{	for (int yy = 0; yy < mid.height; yy++) {
+				bool selflag = (ssel0 <= w0 && w1 < ssel1);
+				unsigned char rv, gv, bv;
+				float value;
+				if(!usePxCache) {
+					float bin0 = float (yy) * binPerPx + minSamples;
+					float bin1 = float (yy + 1) * binPerPx + minSamples;
+					if (int (bin1) == int (bin0))
+						value = freq[half * x + int (bin0)];
+					else {
+						float binwidth= bin1 - bin0;
+						value = freq[half * x + int (bin0)] * (1.f - bin0 + (int)bin0);
+						bin0 = 1 + int (bin0);
+						while (bin0 < int (bin1)) {
+							value += freq[half * x + int (bin0)];
+							bin0 += 1.0;
+						value += freq[half * x + int (bin1)] * (bin1 - int (bin1));
+						value /= binwidth;
+					if (!autocorrelation) {
+						// Last step converts dB to a 0.0-1.0 range
+						value = (value + 80.0) / 80.0;
+					if (value > 1.0)
+						value = float(1.0);
+					if (value < 0.0)
+						value = float(0.0);
+					clip->mSpecPxCache->values[x * mid.height + yy] = value;
+				else
+					value = clip->mSpecPxCache->values[x * mid.height + yy];
+				GetColorGradient(value, selflag, isGrayscale, &rv, &gv, &bv);
+				int px = ((mid.height - 1 - yy) * mid.width + x) * 3;
+				data[px++] = rv;
+				data[px++] = gv;
+				data[px] = bv;
+		}else
+		{	int x0=x*half;
+			double e=exp(1.0f), f=rate/2/half,
+				lmin=log(double(minFreq)),
+				lmax=log(double(maxFreq)),
+				scale=lmax-lmin,
+				expo=exp(scale);
+			for (int yy = 0; yy < mid.height; yy++) {
+				float value;
+				if(true) //!usePxCache)
+				{	float h=double(yy)/mid.height,
+						yy2=exp(h*scale+lmin)/f;
+					if (int(yy2)>=half)
+						yy2=half-1;
+					if (yy2<0)
+						yy2=0;
+					float bin0 = float (yy2);// * binPerPx + minSamples;
+					float bin1 = float (yy2 + 1);// * binPerPx + minSamples;
+						value = freq[x0 + int (bin0)];
+					else {
+						value = freq[x0 + int (bin0)] * (1.f - bin0 + (int)bin0);
+							value += freq[x0 + int (bin0)];
+							bin0 += 1.0;
+						value += freq[x0 + int (bin1)] * (bin1 - int (bin1));
+					if (value > 1.0)
+					if (value < 0.0)
+				else
+				data[px++] = rv;
+				data[px++] = gv;
+				data[px] = bv;
       x++;
Index: TrackArtist.h
RCS file: /cvsroot/audacity/audacity-src/src/TrackArtist.h,v
retrieving revision 1.27
diff -u -r1.27 TrackArtist.h
--- TrackArtist.h	18 Jun 2007 16:10:54 -0000	1.27
+++ TrackArtist.h	5 Nov 2007 21:27:14 -0000
@@ -69,7 +69,7 @@
    void DrawSpectrum(WaveTrack *track,
-                     ViewInfo * viewInfo, bool autocorrelation);
+                     ViewInfo * viewInfo, bool autocorrelation, bool logF);
    void DrawNoteTrack(NoteTrack *track,
                       wxDC & dc, wxRect & r, ViewInfo * viewInfo);
@@ -94,7 +94,7 @@
    void DrawClipSpectrum(WaveTrack *track, WaveClip *clip,
    void SetBackgroundBrushes(wxBrush unselectedBrush, wxBrush selectedBrush,
 			     wxPen unselectedPen, wxPen selectedPen) {
Index: TrackPanel.cpp
RCS file: /cvsroot/audacity/audacity-src/src/TrackPanel.cpp,v
retrieving revision 1.376
diff -u -r1.376 TrackPanel.cpp
--- TrackPanel.cpp	3 Nov 2007 15:15:14 -0000	1.376
+++ TrackPanel.cpp	6 Nov 2007 02:00:14 -0000
@@ -302,6 +302,7 @@
    OnWaveformID,
    OnWaveformDBID,
    OnSpectrumID,
+   OnSpectrumLogID,
    OnPitchID,
    OnSplitStereoID,
@@ -505,6 +506,7 @@
    mWaveTrackMenu->Append(OnWaveformID, _("Waveform"));
    mWaveTrackMenu->Append(OnWaveformDBID, _("Waveform (dB)"));
    mWaveTrackMenu->Append(OnSpectrumID, _("Spectrum"));
+   mWaveTrackMenu->Append(OnSpectrumLogID, _("Spectrum log(f)"));
    mWaveTrackMenu->Append(OnPitchID, _("Pitch (EAC)"));
    mWaveTrackMenu->AppendSeparator();
    mWaveTrackMenu->AppendCheckItem(OnChannelMonoID, _("Mono"));
@@ -1233,7 +1235,8 @@
    if (event.m_x >= GetVRulerOffset() &&
       t->GetKind() == Track::Wave &&
-      ((WaveTrack *) t)->GetDisplay() <= WaveTrack::SpectrumDisplay) {
+      (((WaveTrack *) t)->GetDisplay() <= WaveTrack::SpectrumDisplay
+		||((WaveTrack *) t)->GetDisplay() <= WaveTrack::SpectrumLogDisplay)) {
       *ppTip = _("Click to vertically zoom in, Shift-click to zoom out, Drag to create a particular zoom region.");
       SetCursor(event.ShiftDown()? *mZoomOutCursor : *mZoomInCursor);
@@ -2529,7 +2532,8 @@
    // don't do anything if track is not wave or Spectrum
    if (mCapturedTrack->GetKind() != Track::Wave
-      || ((WaveTrack *) mCapturedTrack)->GetDisplay() > WaveTrack::SpectrumDisplay)
+      && ((WaveTrack *) mCapturedTrack)->GetDisplay() != WaveTrack::SpectrumDisplay
+      && ((WaveTrack *) mCapturedTrack)->GetDisplay() != WaveTrack::SpectrumLogDisplay)
       return;
    mMouseCapture = IsVZooming;
@@ -2575,11 +2579,12 @@
    float min, max, c, l, binSize = 0.0;
-   bool spectrum;
+   bool spectrum, spectrumLog;
    int windowSize, minBins = 0;
    double rate = ((WaveTrack *)track)->GetRate();
    ((WaveTrack *) track)->GetDisplay() == WaveTrack::SpectrumDisplay ? spectrum = true : spectrum = false;
-   if(spectrum) {
+	spectrumLog=(((WaveTrack *) track)->GetDisplay() == WaveTrack::SpectrumLogDisplay);
+	if(spectrum) {
       min = gPrefs->Read(wxT("/Spectrum/MinFreq"), 0L);
       if(min < 0)
          min = 0;
@@ -2590,22 +2595,30 @@
       binSize = rate / windowSize;
       minBins = wxMin(10, windowSize/2); //minimum 10 freq bins, unless there are less
-   else
-      track->GetDisplayBounds(&min, &max);
+   else if(spectrumLog) {
+      min = gPrefs->Read(wxT("/SpectrumLog/MinFreq"), rate/2000.0);
+      if(min < 1)
+         min = 1;
+      max = gPrefs->Read(wxT("/SpectrumLog/MaxFreq"), rate/2.);
+      if(max > rate/2.)
+         max = rate/2.;
+      windowSize = gPrefs->Read(wxT("/Spectrum/FFTSize"), 256);
+      binSize = rate / windowSize;
+      minBins = wxMin(10, windowSize/2); //minimum 10 freq bins, unless there are less
+   }else
+		track->GetDisplayBounds(&min, &max);
    if (IsDragZooming()) {
       // Drag Zoom
       float p1, p2, tmin, tmax;
-      tmin=min;
-      tmax=max;
-      p1 = (mZoomStart - ypos) / (float)height;
-      p2 = (mZoomEnd - ypos) / (float)height;
-      max = (tmax * (1.0-p1) + tmin * p1);
-      min = (tmax * (1.0-p2) + tmin * p2);
       // Enforce maximum vertical zoom
       if(spectrum) {
+			tmin=min;
+			tmax=max;
+			p1 = (mZoomStart - ypos) / (float)height;
+			p2 = (mZoomEnd - ypos) / (float)height;
+			max = (tmax * (1.0-p1) + tmin * p1);
+			min = (tmax * (1.0-p2) + tmin * p2);
          if(min < 0.)
             min = 0.;
          if(max < min + minBins * binSize)
@@ -2615,7 +2628,21 @@
             min = max - minBins * binSize;
+         double xmin = 1-(mZoomEnd - ypos) / (float)height;
+         double xmax = 1-(mZoomStart - ypos) / (float)height;
+			double lmin=log10(min), lmax=log10(max);
+			double d=lmax-lmin;
+			min=wxMax(1.0, pow(10, xmin*d+lmin));
+			max=wxMin(rate/2.0, pow(10, xmax*d+lmin));
       else {
+			tmin=min;
+			tmax=max;
          if (max - min < 0.2) {
             c = (min+max)/2;
             min = c-0.1;
@@ -2640,6 +2667,15 @@
             max = wxMin( rate/2., c + 2*l);
+		{  c = 0.5;
+         double xmin = c-1;
+         double xmax = c+1;
       else {
          if (min <= -1.0 && max >= 1.0) {
             min = -2.0;
@@ -2665,8 +2701,20 @@
          c = (max * (1.0-p1) + min * p1);
          min = wxMax( 0.0, c - 0.5*l);
          max = wxMin( rate/2., min + l);
-      else {
+      }else if(spectrumLog)
+		{  c = 0.5*(min+max);
+         // Enforce maximum vertical zoom
+         l = wxMax( 10. * binSize, (c - min));   //is this a sensible min? MJS
+         c = 1.0-p1;
+         double xmin = wxMax(0, c-0.25);
+         double xmax = wxMin(1, c+0.25);
+			min=pow(10, xmin*d+lmin);
+			max=pow(10, xmax*d+lmin);
+      }else {
          // Zoom in centered on cursor
          if (min < -1.0 || max > 1.0) {
@@ -2702,6 +2750,22 @@
          t = iter.Next();
+   }else if(spectrumLog) {
+      gPrefs->Write(wxT("/SpectrumLog/MaxFreq"), (long)max);
+      gPrefs->Write(wxT("/SpectrumLog/MinFreq"), (long)min);
+      TrackListIterator iter(mTracks);
+      Track *t = iter.First();
+      while (t) {
+         if (t->GetKind() == Track::Wave) {
+            WaveTrack *wt = (WaveTrack *)t;
+            WaveClipList::Node* it;
+            for(it=wt->GetClipIterator(); it; it=it->GetNext()) {
+               WaveClip *clip = it->GetData();
+               clip->mSpecPxCache->valid = false;
+         t = iter.Next();
    else {
       track->SetDisplayBounds(min, max);
@@ -5516,6 +5580,7 @@
       theMenu->Enable(OnWaveformDBID,
                         display != WaveTrack::WaveformDBDisplay);
       theMenu->Enable(OnSpectrumID, display != WaveTrack::SpectrumDisplay);
+      theMenu->Enable(OnSpectrumLogID, display != WaveTrack::SpectrumLogDisplay);
       theMenu->Enable(OnPitchID, display != WaveTrack::PitchDisplay);
       WaveTrack * track = (WaveTrack *)t;
Index: WaveTrack.h
RCS file: /cvsroot/audacity/audacity-src/src/WaveTrack.h,v
retrieving revision 1.48
diff -u -r1.48 WaveTrack.h
--- WaveTrack.h	18 Jun 2007 16:10:54 -0000	1.48
+++ WaveTrack.h	4 Nov 2007 23:45:48 -0000
@@ -310,6 +310,7 @@
       WaveformDisplay,
       WaveformDBDisplay,
       SpectrumDisplay,
+		SpectrumLogDisplay,
       PitchDisplay
    } WaveTrackDisplay;
Index: effects/ToneGen.cpp
RCS file: /cvsroot/audacity/audacity-src/src/effects/ToneGen.cpp,v
retrieving revision 1.46
diff -u -r1.46 ToneGen.cpp
--- effects/ToneGen.cpp	10 Oct 2007 00:16:22 -0000	1.46
+++ effects/ToneGen.cpp	4 Nov 2007 22:51:22 -0000
@@ -50,24 +50,30 @@
    amplitude[1] = float(0.8);
 //   EnableForChirps();
    length = sDefaultGenerateLen;
+	interpolation=0;
 wxString EffectToneGen::GetEffectDescription() {
    // Note: This is useful only after values have been set.
    /// todo update to include *all* chirp parameters??
    const wxChar* waveformNames[] = {wxT("sine"), wxT("square"), wxT("sawtooth"), wxT("square, no alias")};
+   const wxChar* interpolationNames[] = {wxT("linear"), wxT("logarithmic")};
    return wxString::Format(_("Applied effect: Generate %s wave %s, frequency = %.2f Hz, amplitude = %.2f, %.6lf seconds"),
-      waveformNames[waveform], mbChirp ? wxT("chirp") : wxT("tone"), frequency[0], amplitude[0], length);
+      waveformNames[waveform], mbChirp ? wxT("chirp") : wxT("tone"),
+		frequency[0], amplitude[0], length, interpolationNames[interpolation]);
 bool EffectToneGen::PromptUser()
    wxArrayString waveforms;
+   wxArrayString interpolations;
    ToneGenDialog dlog(mParent, mbChirp ? _("Chirp Generator") : _("Tone Generator"));
    waveforms.Add(_("Sine"));
    waveforms.Add(_("Square"));
    waveforms.Add(_("Sawtooth"));
    waveforms.Add(_("Square, no alias"));
+   interpolations.Add(_("Linear"));
+   interpolations.Add(_("Logarithmic"));
    dlog.isSelection= false;
    if (mT1 > mT0) {
@@ -83,6 +89,8 @@
    dlog.amplitude[1] = amplitude[1];
    dlog.length = length;
    dlog.waveforms = &waveforms;
+	dlog.interpolation = interpolation;
+	dlog.interpolations = &interpolations;
    dlog.Init();
    dlog.TransferDataToWindow();
    dlog.Fit();
@@ -96,6 +104,11 @@
    frequency[1] = dlog.frequency[1];
    amplitude[0] = dlog.amplitude[0];
    amplitude[1] = dlog.amplitude[1];
+	interpolation = dlog.interpolation;
+	if (interpolation==0)
+		mbLogInterpolation = false;
+	if (interpolation==1)
+		mbLogInterpolation = true;
    if( !mbChirp )
       frequency[1] = frequency[0];
@@ -341,6 +354,7 @@
       S.TieTextBox(wxT(""), frequency[1], 10);
       S.TieTextBox(_("Amplitude (0-1)"),amplitude[0], 10);
       S.TieTextBox(wxT(""), amplitude[1], 10);
+      S.TieChoice(_("Interpolation:"), interpolation,  interpolations);
    S.EndMultiColumn();
    S.StartMultiColumn(2, wxCENTER);
Index: effects/ToneGen.h
RCS file: /cvsroot/audacity/audacity-src/src/effects/ToneGen.h,v
retrieving revision 1.23
diff -u -r1.23 ToneGen.h
--- effects/ToneGen.h	29 Jul 2007 02:15:36 -0000	1.23
+++ effects/ToneGen.h	4 Nov 2007 22:44:32 -0000
@@ -78,6 +78,7 @@
    double length;
    float logFrequency[2];
    double mCurRate;
+	int interpolation;
    // mSample is an external placeholder to remember the last "buffer"
    // position so we use it to reinitialize from where we left
@@ -114,6 +115,8 @@
    double amplitude[2];
    double length;
    bool isSelection;
+   wxArrayString *interpolations;
  private:
    TimeTextCtrl *mToneDurationT;
Index: widgets/Ruler.cpp
RCS file: /cvsroot/audacity/audacity-src/src/widgets/Ruler.cpp,v
retrieving revision 1.44
diff -u -r1.44 Ruler.cpp
--- widgets/Ruler.cpp	5 Jul 2007 11:55:38 -0000	1.44
+++ widgets/Ruler.cpp	6 Nov 2007 00:08:02 -0000
@@ -144,7 +144,7 @@
 void Ruler::SetFormat(RulerFormat format)
-   // IntFormat, RealFormat, TimeFormat, or LinearDBFormat
+   // IntFormat, RealFormat, RealLogFormat, TimeFormat, or LinearDBFormat
    if (mFormat != format) {
       mFormat = format;
@@ -500,6 +500,32 @@
       mMajor = d * 2.0;
       break;
+   case RealLogFormat:
+      d = 0.000001;
+      // mDigits is number of digits after the decimal point.
+      mDigits = 6;
+      for(;;) {
+         if (units < d) {
+            mMinor = d;
+            mMajor = d*5.0;
+            return;
+         d *= 5.0;
+         if (units < d) {
+            mMinor = d;
+            mMajor = d*2.0;
+            return;
+         d *= 2.0;
+         mDigits--;
+         // More than 10 digit numbers?  Something is badly wrong.
+         // Probably units is coming in with too high a value.
+         wxASSERT( mDigits >= -10 );
+		mDigits++;
+      mMinor = d;
+      mMajor = d * 2.0;
+      break;
@@ -535,6 +561,13 @@
          s.Printf(wxString::Format(wxT("%%.%df"), mDigits), d);
       break;
+      if (mMinor >= 1.0)
+         s.Printf(wxT("%d"), (int)floor(d+0.5));
+      else {
+         s.Printf(wxString::Format(wxT("%%.%df"), mDigits), d);
+      break;
    case TimeFormat:
       if (major) {
          if (d < 0) {
@@ -606,7 +639,8 @@
    if (mUnits != wxT(""))
-      s = (s + wxT(" ") + mUnits);
+      s = (s + mUnits);
+//      s = (s + wxT(" ") + mUnits);
    return s;
@@ -882,8 +916,9 @@
    else {
       // log case
-      double loLog = log10(mMin);
+      mDigits=2;	//TODO: implement dynamic digit computation
+		double loLog = log10(mMin);
       double hiLog = log10(mMax);
       double scale = mLength/(hiLog - loLog);
       int loDecade = (int) floor(loLog);
@@ -895,28 +930,38 @@
       // Major ticks are the decades
       double decade = startDecade;
-      for(i=loDecade; i<hiDecade; i++) {
-         if(i!=loDecade) {
-            val = decade;
-            if(val > mMin && val < mMax) {
+		int delta=hiDecade-loDecade, steps=abs(delta);
+		double step = delta>=0 ? 10 : 0.1;
+		double rMin=wxMin(mMin, mMax), rMax=wxMax(mMin, mMax);
+		for(i=0; i<=steps; i++)
+		{  // if(i!=0)
+			{  val = decade;
+            if(val > rMin && val < rMax) {
                pos = (int)(((log10(val) - loLog)*scale)+0.5);
                Tick(pos, val, true);
-         decade *= 10.;
+         decade *= step;
       // Minor ticks are multiples of decades
-         for(j=2; j<=9; j++) {
+		int start, end, mstep;
+		if (delta > 0)
+		{	start=2; end=10; mstep=1;
+		}else
+		{	start=9; end=1; mstep=-1;
+		steps++;
+      for(i=0; i<=steps; i++) {
+         for(j=start; j!=end; j+=mstep) {
             val = decade * j;
-            if(val >= mMin && val < mMax) {
+            if(val >= rMin && val < rMax) {
                Tick(pos, val, false);
-         decade *= 10.;
+         decade *= step;
Index: widgets/Ruler.h
RCS file: /cvsroot/audacity/audacity-src/src/widgets/Ruler.h,v
retrieving revision 1.20
diff -u -r1.20 Ruler.h
--- widgets/Ruler.h	5 Jul 2007 11:55:38 -0000	1.20
+++ widgets/Ruler.h	5 Nov 2007 23:39:36 -0000
@@ -27,7 +27,8 @@
    enum RulerFormat {
       IntFormat,
       RealFormat,
-      TimeFormat,
+		RealLogFormat,
+		TimeFormat,
       LinearDBFormat,
amicheler
Re: Additions: log(f) axis in spectrum display; log Tongen
Post by amicheler » Tue Nov 06, 2007 8:05 am
Hi all,
some more which I've written now: a convolution effect.
Its computations seem valid, but there's a bug which I couldn't fix:
after the effect has run, the only way to proceed is to save the project and exit.
then start the project again. Else Audacity crashes.
If anyone with more experience concerning the internals of Audacity knows,
how to fix the bug then it will be a nice usable effect. :-)
In this patch my last patch (spectrum display & tongen) is included also.
(how can I prepare a patch which is based on a patched CVS? Can anyone explain me how to do this?)
Cheers,
Andreas
Code: Select all
? effects/Convolution.cpp
? effects/Convolution.h
Index: BatchCommands.cpp
RCS file: /cvsroot/audacity/audacity-src/src/BatchCommands.cpp,v
retrieving revision 1.29
diff -u -r1.29 BatchCommands.cpp
--- BatchCommands.cpp	7 May 2007 00:59:08 -0000	1.29
+++ BatchCommands.cpp	6 Nov 2007 03:18:46 -0000
@@ -56,6 +56,7 @@
    wxT("SaveHqMaster1"),
    wxT("SaveHqMaster2"),
    wxT("StereoToMono"),
+   wxT("Convolution"),
    wxT("ExportFlac"),
    wxT("ExportMp3"),
    wxT("ExportOgg"),
@@ -231,6 +232,7 @@
 /* i18n-hint: Effect name translations must agree with those used elsewhere, or batch won't find them */
    AddToChain( wxT("StereoToMono") );
+   AddToChain( wxT("Convolution") );
    AddToChain( wxT("Normalize") );
    AddToChain( wxT("SaveHqMaster1") );
    AddToChain( wxT("NoiseRemoval") );
@@ -476,6 +478,14 @@
       wxMessageBox(_("Stereo To Mono Effect not found"));
       return false;
+   } else if (command == wxT("Convolution")) {
+      // Convolution is an effect masquerading as a menu item.
+      Effect * f = GetEffectFromCommandName(wxT("Convolution"));
+      if (f != NULL) {
+         return ApplyEffectCommand(f, command, params);
+      wxMessageBox(_("Convolution Effect not found"));
+      return false;
    } else if (command == wxT("ExportMp3")) {
       return WriteMp3File(filename, 0); // 0 bitrate means use default/current
    } else if (command == wxT("ExportWav")) {
Index: Menus.cpp
RCS file: /cvsroot/audacity/audacity-src/src/Menus.cpp,v
retrieving revision 1.350
diff -u -r1.350 Menus.cpp
--- Menus.cpp	27 Oct 2007 16:06:15 -0000	1.350
+++ Menus.cpp	6 Nov 2007 03:29:40 -0000
@@ -357,6 +357,11 @@
       c->SetCommandFlags(wxT("Stereo To Mono"),
          AudioIONotBusyFlag | StereoRequiredFlag | WaveTracksSelectedFlag,
          AudioIONotBusyFlag | StereoRequiredFlag | WaveTracksSelectedFlag);
+      c->AddItem(wxT("Convolution"),      _("&Convolution"),            FN(OnConvolution));
+      c->SetCommandFlags(wxT("Convolution"),
+         AudioIONotBusyFlag | StereoRequiredFlag | WaveTracksSelectedFlag,
+         AudioIONotBusyFlag | StereoRequiredFlag | WaveTracksSelectedFlag);
    c->AddSeparator();
@@ -557,7 +562,13 @@
-      c->AddItem(wxT("MixAndRender"),       _("&Mix and Render"),             FN(OnMixAndRender));
+		c->AddItem(wxT("MixAndRender"),       _("&Mix and Render"),             FN(OnMixAndRender));
       c->SetCommandFlags(wxT("MixAndRender"),
                          AudioIONotBusyFlag | WaveTracksSelectedFlag,
                          AudioIONotBusyFlag | WaveTracksSelectedFlag);
@@ -887,6 +898,7 @@
    mNormalizeIndex = -1;
    mStereoToMonoIndex = -1;
+   mConvolutionIndex = -1;
    for (unsigned int i = 0; i < effects->GetCount(); i++) {
       wxString effectIdentifier = (*effects)[i]->GetEffectIdentifier();
@@ -896,6 +908,9 @@
       else if (effectIdentifier == wxT("StereoToMono")) {
          mStereoToMonoIndex = i;
+      else if (effectIdentifier == wxT("Convolution")) {
+         mConvolutionIndex = i;
@@ -2055,6 +2070,12 @@
       OnEffect(ALL_EFFECTS, mStereoToMonoIndex);
+void AudacityProject::OnConvolution(int index)
+   if (mConvolutionIndex >= 0)
+      OnEffect(ALL_EFFECTS, mConvolutionIndex);
 void AudacityProject::OnProcessPlugin(int index)
    OnEffect(PLUGIN_EFFECT | PROCESS_EFFECT, index);
Index: Menus.h
RCS file: /cvsroot/audacity/audacity-src/src/Menus.h,v
retrieving revision 1.115
diff -u -r1.115 Menus.h
--- Menus.h	30 Sep 2007 18:59:26 -0000	1.115
+++ Menus.h	6 Nov 2007 03:20:10 -0000
@@ -273,11 +273,13 @@
 void OnImportCleanSpeechPresets();
 void OnExportCleanSpeechPresets();
 void OnStereoToMono(int index);
+void OnConvolution(int index);
 void ResolveEffectIndices(EffectArray *effects);
 wxString BuildCleanFileName(wxString fileName);
 int  mNormalizeIndex;
 int  mStereoToMonoIndex;
+int  mConvolutionIndex;
         // Help Menu
Index: Printing.cpp
             break;
+            break;
             break;
             break;
          break;
                break;
+               break;
                break;
                break;
             break;              // case Wave
-      // Spectrum
+	{  // Spectrum
       if (r.height < 60)
          return;
-         maxFreq = freq;
+			maxFreq = freq;
-      if(minFreq < 0) {
-         minFreq = 0;
+	   if(minFreq < 0) {
+	      minFreq = 0;
          draw the ruler
       vruler->Draw(*dc);
+	{  // SpectrumLog
+         return;
+			maxFreq = freq;
+	   if(minFreq < 1) {
+	      minFreq = 1;
+         draw the ruler
+   int maxFreq;
+	if (!logF)
+	else
    if(maxFreq > ifreq)
       maxFreq = ifreq;
-   if(minFreq < 0) {
-      minFreq = 0;
+	int minFreq;
+	if (!logF)
+	   if(minFreq < 0) {
+	      minFreq = 0;
+	}else
+	   if(minFreq < 1) {
    int x = 0;
-         float value;
-         if(!usePxCache) {
-            else {
-                  bin0 += 1.0;
-            if (value > 1.0)
-            if (value < 0.0)
-         else
-         data[px++] = rv;
-         data[px++] = gv;
-         data[px] = bv;
+		if (!logF)
+				float value;
+				if(!usePxCache) {
+					else {
+							bin0 += 1.0;
+					if (value > 1.0)
+					if (value < 0.0)
+				else
+				data[px++] = rv;
+				data[px++] = gv;
+				data[px] = bv;
+		}else
+		{	int x0=x*half;
+				scale=lmax-lmin,
+				expo=exp(scale);
+				float value;
+						yy2=half-1;
+					if (yy2<0)
+						yy2=0;
+					else {
+							bin0 += 1.0;
+					if (value > 1.0)
+					if (value < 0.0)
+				else
+				data[px++] = rv;
+				data[px++] = gv;
+				data[px] = bv;
       x++;
@@ -69,7 +69,7 @@
@@ -94,7 +94,7 @@
@@ -302,6 +302,7 @@
    OnWaveformID,
    OnWaveformDBID,
    OnSpectrumID,
+   OnSpectrumLogID,
    OnPitchID,
    OnSplitStereoID,
@@ -505,6 +506,7 @@
       return;
-   bool spectrum;
-   if(spectrum) {
+	if(spectrum) {
       if(min < 0)
          min = 0;
-   else
+      if(min < 1)
+         min = 1;
+      if(max > rate/2.)
+         max = rate/2.;
+   }else
       // Drag Zoom
-      tmin=min;
-      tmax=max;
       if(spectrum) {
+			tmin=min;
+			tmax=max;
          if(min < 0.)
             min = 0.;
       else {
+			tmin=min;
+			tmax=max;
             c = (min+max)/2;
             min = c-0.1;
+		{  c = 0.5;
       else {
             min = -2.0;
-      else {
+         c = 1.0-p1;
+      }else {
          t = iter.Next();
+      while (t) {
+         t = iter.Next();
    else {
Index: WaveTrack.h
@@ -310,6 +310,7 @@
       WaveformDisplay,
       WaveformDBDisplay,
       SpectrumDisplay,
       PitchDisplay
    } WaveTrackDisplay;
Index: effects/LoadEffects.cpp
RCS file: /cvsroot/audacity/audacity-src/src/effects/LoadEffects.cpp,v
retrieving revision 1.57
diff -u -r1.57 LoadEffects.cpp
--- effects/LoadEffects.cpp	16 Sep 2007 13:46:00 -0000	1.57
+++ effects/LoadEffects.cpp	6 Nov 2007 03:18:52 -0000
@@ -36,6 +36,7 @@
 #include "Reverse.h"
 #include "Silence.h"
 #include "StereoToMono.h"
+#include "Convolution.h"
 #include "ToneGen.h"
 #include "TruncSilence.h"
 #include "Wahwah.h"
@@ -112,6 +113,7 @@
    Effect::RegisterEffect(new EffectRepeat());
    Effect::RegisterEffect(new EffectReverse());
    Effect::RegisterEffect(new EffectStereoToMono(), HIDDEN_EFFECT);// NOT in normal effects list.
+   Effect::RegisterEffect(new EffectConvolution());
    Effect::RegisterEffect(new EffectTruncSilence(), SIMPLE_EFFECT);
    Effect::RegisterEffect(new EffectWahwah());
@@ -50,24 +50,30 @@
+	interpolation=0;
    if (mT1 > mT0) {
@@ -83,6 +89,8 @@
    dlog.Init();
    dlog.Fit();
@@ -96,6 +104,11 @@
    if( !mbChirp )
@@ -341,6 +354,7 @@
    S.EndMultiColumn();
@@ -78,6 +78,7 @@
    double length;
    double mCurRate;
@@ -114,6 +115,8 @@
    double length;
    bool isSelection;
  private:
@@ -144,7 +144,7 @@
       mFormat = format;
       mMajor = d * 2.0;
       break;
+      d = 0.000001;
+      mDigits = 6;
+      for(;;) {
+         if (units < d) {
+            mMinor = d;
+            mMajor = d*5.0;
+            return;
+         d *= 5.0;
+         if (units < d) {
+            mMinor = d;
+            mMajor = d*2.0;
+            return;
+         d *= 2.0;
+         mDigits--;
+		mDigits++;
+      mMinor = d;
+      mMajor = d * 2.0;
+      break;
       break;
+      else {
+      break;
    case TimeFormat:
       if (major) {
          if (d < 0) {
@@ -606,7 +639,8 @@
+      s = (s + mUnits);
    return s;
@@ -882,8 +916,9 @@
    else {
       // log case
-         if(i!=loDecade) {
-            val = decade;
+		{  // if(i!=0)
+			{  val = decade;
-         decade *= 10.;
+         decade *= step;
+		if (delta > 0)
+		}else
+		steps++;
             val = decade * j;
-         decade *= 10.;
+         decade *= step;
@@ -27,7 +27,8 @@
    enum RulerFormat {
       IntFormat,
       RealFormat,
-      TimeFormat,
+		RealLogFormat,
+		TimeFormat,
       LinearDBFormat,
