Hi all !,
Does anyhow knows a way to activate recording automatically when Audacity is launched ?
I am a Windows XP user
Thanks a lot
Natalino
Automatic recording at start-up
Re: Automatic recording at start-up
I don't think that's possible.
I also can't think of any reason to want that feature.
The reason is that I would like to record a Internet Radio program starting in the middle of night.
I am able to schedule Audacity to be launched at a certain time (Windows Xp utility) , but I have no way to tell Audacity to start recording !
Bye
Natalino
Bye
Natalino
waxcylinder
If I remember rightly, there was a post on the old board (all postings now unfortunately lost) that explained how to get Audacity to start recording at a particular time and also stop recording at the required end-time.
Unfortunately I cannot remember the instructions for this - maybe somebody else can? Or maybe the original respondent will read this and repost?
Update 10Aug: I've just noticed from a post on the 1.3 section of the forum that apparently a timer record function was introduced in 1.3.x - you may wish to upload 1.3 and try that - you have both 1.2 and 1.3 on the same PC with no problems. I tend to use 1.3 all the time now anyway as I find it stable enough for my needs.
Thanks for the update.
Timer record is exactly the feature I need.
Natalino
Natalino
Hello there!
Automatic recording at startup is a great feature in auda city. But can u tell me please if audacity can start automatically on system starup and start recording ?
I want to record all voice chats in my absence on my home machine.
I think the only way to do that is to set the Audacity timer feature to start about a minute after the machine boots.
You can leave the machine operating all the time and use Sound Activated Recording. Audacity will only record when there is noise, music, or voice.
