[v.2.2.1] Problem with exporting stereo tracks
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
Permanent link to this post Posted by MIMMO61 » Sun Feb 18, 2018 12:37 pm
Good morning
I noticed a problem when exporting single stereo tracks,
The procedure is as follows:
1- amount the stereo track and then separate the two tracks.
2- first select the right track and perform the export (wav) of the selected track.
3- first select the left track and perform the export (wav) of the selected track.
When I check the exported tracks, only the left track results without sound.
After a few attempts, I managed to bring the balance cursor to the central position (0).
As far as the left track is concerned, the problem does not exist even if the balancing cursor is positioned on the left.
It seems to me that in the previous version of Audacity (2.1.2) even if the cursor was in the right position the track was exported without problems
Thank you
MIMMO61
Re: [v.2.2.1] Problem with exporting stereo tracks
Permanent link to this post Posted by steve » Sun Feb 18, 2018 12:52 pm
MIMMO61 wrote:and then separate the two tracks.
If you want two mono tracks, use "Split Stereo to Mono"
Permanent link to this post Posted by MIMMO61 » Sun Feb 18, 2018 2:29 pm
Thank you very much.
MIMMO61
Return to Audacity 2.x Feedback and Reviews
Who is online
