Noise Reduction Issue (Version 2.1.3)
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
Pred1140
Post by Pred1140 » Fri Aug 11, 2017 4:27 am
When I attempt to use the noise reduction option, I select a portion that is only white noise and hit get noise profile. Then, I select the entire audio and select ok. It worked before but now it won't apply any changes at all. All it does is say it is applying changes but the noise isn't reduced whatsoever. It stays default.
Re: Noise Reduction Issue (Version 2.1.3)
Post by kozikowski » Fri Aug 11, 2017 4:56 am
How long is the show? Some of these tools have upper limits on how much work they'll do—how many hours—in one pass.
Pred1140
Post by Pred1140 » Fri Aug 11, 2017 4:58 am
Close to 5 minutes. I fixed it though. I didn't know the sensitivity played a part in it. It was put as 0 but once I raised it, it fixed. Thank you though!
