distortion plugin needs harmonizer for harmonics
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
hi their, I've got audacity version 2.1.3 nightly beta. can you please write this in distortion plugin called expand and harmonize the music?
Re: distortion plugin needs harmonizer for harmonics
If you are on Windows, there is a free VST plugin called DtBlkFx , that works in Audacity, which can create harmonics, frequency-tracker (aka harmonize), vocoder, distortion, & lots more.yugioh47 wrote:... can you please write this in distortion plugin called expand and harmonize the music?
thanks manTrebor wrote:If you are on Windows, there is a free VST plugin called DtBlkFx , that works in Audacity, which can create harmonics, frequency-tracker (aka harmonize), vocoder, distortion, & lots more.yugioh47 wrote:... can you please write this in distortion plugin called expand and harmonize the music?
