Project window in program vs. in manual
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
Permanent link to this post Posted by pwabrahams » Mon Sep 19, 2016 11:49 am
When you start up Audacity 2.1.2, the project window does not have the same layout as it does in the Help. This can be quite confusing to new users (or returning users like me).
pwabrahams
Re: Project window in program vs. in manual
Permanent link to this post Posted by steve » Mon Sep 19, 2016 11:58 am
Looks the same to me.
Check your Audacity version in "Help > About Audacity".
Which manual are you looking at? This is the on-line version: http://manual.audacityteam.org/
Which operating system are you using?
If you have customised the layout at any time, you can reset the toolbars: "View menu > Toolbars > Reset toolbars"
Permanent link to this post Posted by waxcylinder » Mon Sep 19, 2016 12:19 pm
Well that image was created on my W10 laptop with Audacity default settings.
The only changes were the window moved inwards from the right a little to reduce the image size a tad and a similar squeeze at the bottom. Plus I added the stereo audio track and the label track. And Bill Wharrie added the blue numbers to index the image (plus he made it into a very clever imagemap) that you can drill into for detail on the various elements.
All the Toolbars should be in their default positions.
Can you past a screenshot of the layout you get?
waxcylinder
The version has changed, it seems
Permanent link to this post Posted by pwabrahams » Mon Sep 19, 2016 2:33 pm
I found the problem: my configuration files came from a slightly older version of Audacity. I'm running Kubuntu 14.04, and I assumed that I had the latest version of Audacity since I had downloaded it from the official Ubuntu repositories. A few versions back, the recording meter and playback meter were both on the same line. I suspected that there was a version problem, so I downloaded 2.1.2 from the Audacity repository. Though I had the latest Audacity, I still had the older configuration files since the download didn't replace them.
I deleted my configuration files, restarted Audacity, and now everything is in sync.
pwabrahams
Permanent link to this post Posted by waxcylinder » Mon Sep 19, 2016 5:41 pm
phew, that's a relief 8-)
thanks for reporting back.
WV
waxcylinder
Return to Audacity 2.x Feedback and Reviews
Who is online
Users browsing this forum: No registered users and 2 guests
