renaming project files
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
mickthefish
Operating System: Windows XP
Post by mickthefish » Fri Mar 18, 2016 11:56 am
i knew that if i renamed a project file from audacity it wouldn't load,however I've just renamed some
old files back to ".aup "& they work perfectly. its saved me reams of work-mickthefish. :lol:
Re: renaming project files
Post by steve » Fri Mar 18, 2016 12:01 pm
The safest way to rename a project is to:
1) Open the project in Audacity,
2) "File menu > Check dependencies". If the project is not self contained, select the option to copy the dependencies into the project.
3) Use "File menu > Save Project As" and enter a new name. This will create a new, self contained copy of the project (a new AUP file and a new _data folder). Remember to keep the AUP file and _data folder together and avoid renaming them manually.
mickthefish
Post by mickthefish » Wed Mar 30, 2016 8:37 am
thanks for the tip steve it should keep me busy for a while mickthefish.
