Version 2.1.1.0 doesn't "remember" equalization :¬(
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
Permanent link to this post Posted by Trebor » Fri Jul 24, 2015 6:22 am
Audacity 2.1.1.0 running on Windows Vista.
If you create an equalization curve, ( either by drawing it, or using the graphic-equalizer) , then apply it , when you go back to the equalizer that curve has gone , ( also true if you use a preset equalization curve ).
In previous versions of Audacity the last-used equalization settings were retained in that scenario , ( even if you didn't save them as a preset ).
Under 2.1.1.0 if I want to re-apply an equalization I have to re-draw the curve ,
or re-select the same preset from the equalizer menu.
The equalizer "remembering" the last-used settings was much more convenient.
Trebor
Re: Version 2.1.1.0 doesn't "remember" equalization :¬(
Permanent link to this post Posted by steve » Fri Jul 24, 2015 8:30 am
It's a bug that was unfortunately not noticed until just after 2.1.1 was released.
It has been given "P1" (highest) priority so something must be done about it (hopefully a full fix) before the next release.
http://bugzilla.audacityteam.org/show_bug.cgi?id=1081
Permanent link to this post Posted by Trebor » Fri Jul 24, 2015 5:06 pm
It's worth enduring that equalizer-bug to have a version of Audacity which has the much-awaited real-time effect-adjustment , ( and better noise-reduction algorithm ). Come to think on it , I could use a VST plugin equalizer in the meantime until the bug is fixed, ( the VST settings are "remembered" even after closing Audacity).
Trebor
Permanent link to this post Posted by Gale Andrews » Sat Jul 25, 2015 7:15 pm
Trebor wrote:It's worth enduring that equalizer-bug to have a version of Audacity which has the much-awaited real-time effect-adjustment , ( and better noise-reduction algorithm ). Come to think on it , I could use a VST plugin equalizer in the meantime until the bug is fixed, ( the VST settings are "remembered" even after closing Audacity).
Even so, you could use 2.1.0 without the EQ bug. 2.1.0 has real-time preview and saved VST settings.
Permanent link to this post Posted by Trebor » Sat Aug 01, 2015 7:09 pm
Trebor wrote:... Come to think on it , I could use a VST plugin equalizer in the meantime until the bug is fixed ...
Video demo of Voxengo 'Marvel' equalizer in Audacity 2-1-1.ogv
30 second (1/4 size) demo video of VST-equalizer working in real-time in Audacity 2-1-1
(929.4 KiB) Downloaded 583 times
Voxengo Marvel Equalizer installation , choose ''VST2'' , install in Audacity plugins folder.png
Choose "VST2" , not "VST3", and install in Audacity plugins folder.
Voxengo Marvel Equalizer installation , choose ''VST2'' , install in Audacity plugins folder.png (19.93 KiB) Viewed 2369 times
Plugin source : http://www.voxengo.com/product/marvelgeq/
Music Source : http://ccmixter.org/files/texasradiofish/26458
Trebor
Permanent link to this post Posted by toddgilbert » Thu Jul 13, 2017 5:22 pm
I have 2.1.3 how do I get real time preview?
toddgilbert
Permanent link to this post Posted by Trebor » Thu Jul 13, 2017 7:56 pm
toddgilbert wrote:I have 2.1.3 how do I get real time preview?
Download the free Voxengo* equalizer plugin from ... http://www.voxengo.com/product/marvelgeq/
and install the VST2 version for Windows.
NB: Audacity's built-in effect Bass&Treble is a simple equalizer with real-time preview, which may suffice.
[*other VST equalizer plugins are available ].
Trebor
Return to Audacity 2.x Feedback and Reviews
Who is online
Users browsing this forum: No registered users and 2 guests
