Remember that frequency smoothing counts bands now. The equivalence of 6 to the old 150 Hz assumes a 44100 sample rate.Robert J. H. wrote:My thoughts too.Gale Andrews wrote:I am pleased we finally increased default smoothing, but don't you think it looks odd to have a default at the extreme of a slider scale?Paul L wrote: Default smoothing will be 6 in future versions.
The extreme should in any case be higher - 10 or 12.
If I'm correct, 6 is approx. 150 Hz and we used up to 500 Hz in the old effect. This might not be necessary anymore with the partially new algorithm but who knows.
What about a track with 16 kHz sample rate?
Robert
Verdict on the settings for new Noise Reduction?
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
Re: Verdict on the settings for new Noise Reduction?
- Quality Assurance
So what is the equivalence of 6 at for example 96000 Hz, or 8000 Hz or 16000 Hz (which a voice track might be)?Paul L wrote:Remember that frequency smoothing counts bands now. The equivalence of 6 to the old 150 Hz assumes a 44100 sample rate.Robert J. H. wrote:My thoughts too.Gale Andrews wrote:I am pleased we finally increased default smoothing, but don't you think it looks odd to have a default at the extreme of a slider scale?Paul L wrote: Default smoothing will be 6 in future versions.
Robert
It seems you are still discouraging frequency smoothing above 6 by setting 6 as the maximum. Are you so discouraging?
https://soundcloud.com/blizzkrut/sets/a ... nd-problem which is voice with heavy noise (or a normalized version with DC offset removed) needs more than smoothing of 6 in my opinion to reduce artifacts on the voice in the noise-reduced result.
What settings would you use on that? The Forum topic those samples comes from is http://forum.audacityteam.org/viewtopic ... 46&t=87385.
Robert J. H.
If I don't err, the smoothing over 7 bands (since factor 0 = 1 band) for different sample rates are as follows - all in Hertz, except last column:Gale Andrews wrote:So what is the equivalence of 6 at for example 96000 Hz, or 8000 Hz or 16000 Hz (which a voice track might be)?Paul L wrote:Remember that frequency smoothing counts bands now. The equivalence of 6 to the old 150 Hz assumes a 44100 sample rate.Robert J. H. wrote:My thoughts too.Gale Andrews wrote:I am pleased we finally increased default smoothing, but don't you think it looks odd to have a default at the extreme of a slider scale?Paul L wrote: Default smoothing will be 6 in future versions.
Robert
Code: Select all
Sample Rate Bandwidth Smoothing factor
8000 27.34375 37.5875
16000 54.6875 18.29375
22050 75.36621094 13
32000 109.375 8.646875
44100 150.7324219 6
48000 164.0625 5.43125
88200 301.4648438 2.5
96000 328.125 2.215625Of course, the window length in seconds changes as well and thus the results are presumably not comparable - I haven't made all the tests needed.
Robert
The higher the "smoothing" factor, the more damage is done by the effect.Gale Andrews wrote:It seems you are still discouraging frequency smoothing above 6 by setting 6 as the maximum. Are you so discouraging?
It may not be so noticeable with speech recordings. but with high quality music recordings the damage is very evident with the new default settings if you listen to the decay of notes.
As a simple demonstration:
1) Generate a few seconds of Pink Noise and Normalize to -46 dB (about -60 dB RMS). This is a reasonable good approximation of low level noise that one might want to remove from a good quality original recording.
2) Import a really good quality music recording that has very low noise - piano music would be a good choice for demonstration purposes.
3) Create a noise sample from the Pink Noise
4a) Apply to the piano music with "Residue" selected. Note how much of the music is present in the residue.
4b) Apply to a mix of the noise and the music - notice how the notes decay much faster than the original.
Ah well, that might be remedied by allowing the attack and release sliders to be visible again, (release more so than attack,) which is another debate.steve wrote:The higher the "smoothing" factor, the more damage is done by the effect.Gale Andrews wrote:It seems you are still discouraging frequency smoothing above 6 by setting 6 as the maximum. Are you so discouraging?
It's a debate that we had about 12 months ago.Paul L wrote:Ah well, that might be remedied by allowing the attack and release sliders to be visible again, (release more so than attack,) which is another debate.
A problem adding more controls is the high degree of interdependency between controls.
Yes. We have jumped from one extreme of the trade-off to the other.Gale Andrews wrote:don't you think it looks odd to have a default at the extreme of a slider scale?
waxcylinder
My 2c worth
I shall certainly be sticking with the 12,6,0 settings - it's been producing excellent results on the Dublin City FM music shows that I record and post online weekly for a couple of DJ friends.
No-one has complained about the quality of the audio.
Personally I don't think we should have changed this default setting - but sadly it's probably too late now for 2.1.2 now that we are in freeze mode.
We may need to change the advice in the Manual to advise users to choke down the setting for music quality.
Peter
Peter
- Quality Assurance
You presumably have high quality audio with very little noise.waxcylinder wrote:I shall certainly be sticking with the 12,6,0 settings - it's been producing excellent results on the Dublin City FM music shows that I record and post online weekly for a couple of DJ friends.
For people who really need noise removal, frequency smoothing of 0 was a poor default. We've had too many complaints about it.
I thought smoothing of 6 as a default was OK, it was the same smoothing that we had before at 44100 Hz. I think the new effect needs smoothing more than the old effect did - that is definitely so on the material I work with, which is very quiet music where noise must be dealt with.
With so many use cases, we should not have a smoothing default at the end of the scale, and should not have a much lower slider maximum than we had before. A default of 3 with a slider maximum of 12 would be acceptable too, I think. Importantly, that encourages experimentation in both slider directions, and suggests less may be better than more.
The advice may need to be subtly changed, yes. I think the current advice assumes music rather than speech, but clearly a lot of users are working with speech.waxcylinder wrote:We may need to change the advice in the Manual to advise users to choke down the setting for music quality.
- Quality Assurance
Yes, I know. I dislike that, and I sometimes miss the ability to control the release.steve wrote:The higher the "smoothing" factor, the more damage is done by the effect.Gale Andrews wrote:It seems you are still discouraging frequency smoothing above 6 by setting 6 as the maximum. Are you so discouraging?
But the whole thing is a trade off. With higher noise levels, or quieter music, the loss of attack can be subjectively less bad than artifacting.
It is a problem, but more controls could be hidden behind an "Advanced" checkbox, or perhaps separated into another box.steve wrote:Paul L wrote:Ah well, that might be remedied by allowing the attack and release sliders to be visible again, (release more so than attack,) which is another debate.
Also do we have to have the interdependency? Could some filter to mask artifacting be applied "over the top" of the effect, like some kind of post-processing?
That's an interesting question. It's really a question of design.Gale Andrews wrote:Also do we have to have the interdependency?
We now have a noise reduction algorithm that works better than the old Noise Removal effect, but users find it more difficult to interact with.
The algorithm has many interdependent parameters, but it should really not be a concern to the user what the algorithm is, precisely how it works, or how its parameters interact with each other. The user just needs to be able to use the effect - preferably without needing to read a manual. At one end there is the algorithm with lots of interdependent parameters - at the other end (hopefully) is the user interface in which "A" leads intuitively to "B".
