Discussion of noise reduction goes from about 6:50 to 16:30. Also that page contains three audio clips, one "before" and two "afters" comparing the effect in the two versions.
But I thought the settings chosen were not a fair comparison. 2.0.6 was made to sound worse than it should have with a long attack/release setting.
I reproduce here a comment I made at that page, setting up what I think is a fairer comparison. The difference is subtler but still I think noticeable. 2.1.0 should improve the removal of noise that is mixed with foreground sounds, as in Daniel's example, of himself talking over a loud fan.
I want to make what I think is a fairer comparison of the two effects. In each I selected exactly 5 seconds starting at 11.2 in the first .wav clip for noise profile.
First, 2.0.6, with settings 24 (as in your examples), 5 (Sensitivity), 0 (frequency smoothing), 0.1 (attack/release). Really, 0.5 for attack/release makes a very unfair comparison, while 0.1 is the built-in release time for 2.1.0 and attack is shorter. 5 is the smallest whole number sensitivity value that makes all "tinklebell" artifacts in the pauses go away, as seen in spectrogram.
https://clyp.it/me1x5urj
Better sounding than Daniel's settings.
As above except frequency smoothing of 150, the default, which I suspect most people used without changing it. Still better, it takes some whistly effects out of the breaths.
https://clyp.it/r1zbfds4
Now in version 2.1.0, reduction 24, sensitivity 5 (coincidentally what I get by following the same procedure of just enough to banish tinklebells), and smoothing 0.
https://clyp.it/azme3s4j
And again, with smoothing 6, which is in fact the equivalent of old smoothing of 150 Hz when the sample rate is the usual 44100 Hz.
https://clyp.it/po0x1nvf
I think the differences between versions are now subtler but still noticeable.
