Hi
I am new to this program, in fact I just first used it today to record some classic piano pieces, turn out most of my export command are not working and I got this unworkable .File extension when I asked them to do FLAC or WAV.
I still have all the saves and files which are completely working. They just doesn't to willing to leave their post...
Please help, this is a very important works and I am desperately try to get it.
Cheers.
Can't export Help!
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
Re: Can't export Help!
Please read the instructions highlighted in red near the top of the page, then post on the appropriate board, ensuring that you include the information stated in the red/pink text at the top of that page.
We cannot see your setup and are not able to answer questions without the necessary information. See here for brief guidelines about using the forum: http://forum.audacityteam.org/viewtopic ... 49&t=63799
- Quality Assurance
To guess at your issue, don't add dots (periods) into the file name. Audacity warned you about that but it seems you ignored the warning. Please see: http://manual.audacityteam.org/o/man/fa ... extensions .e22big wrote:I got this unworkable .File extension when I asked them to do FLAC or WAV.
If that is not the answer you will need to give the information Steve mentioned in the correct board for your operating system.
Please explain what that means.e22big wrote:They just doesn't to willing to leave their post.
