I've successfully created and exported a surround sound FLAC file.
Prior to the export, I get the option to assign tracks to channels. The only problem is that the channels just have numbers - not names.
E.g.
With a bit of trial and error, I was able to get everything in the right order.
It would be really useful if the channels were labeled as Front Left, Centre, Front Right, Surround Left, Surround Right, LFE etc.
In the meantime - is there a handy guide to which channel is which?
Surround / Multitrack Export Channel Names
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
Re: Surround / Multitrack Export Channel Names
Terrific.edent wrote:I've successfully created and exported a surround sound FLAC file.
Unfortunately it is not straightforward.edent wrote:It would be really useful if the channels were labeled as Front Left, Centre, Front Right, Surround Left, Surround Right, LFE etc.
There are different "standard" channel mappings depending on the file format.
To complicate the matter further, not all hardware / software adhere to the "standards".
You will find some useful information in these links:
http://wiki.hydrogenaudio.org/index.php ... ltichannel
http://en.wikipedia.org/wiki/Surround_sound
GalProducer
Thanks Steve for this answer. Actually this is what brought me to this forum, lol. I was browsing about multichannel and test streams.
I am new with Audacity and trying to make my own music and also remix some songs into dubstep. However, I have some problems with decoding channels into AAc stream sometimes. What do you guys suggest?
- Quality Assurance
Be specific what the problems are.GalProducer wrote:I have some problems with decoding channels into AAc stream sometimes. What do you guys suggest?
