how to export the waveform to the format *txt
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
jimena
Post by jimena » Sun Apr 06, 2014 3:13 pm
i only can export to the format *txt when i´m in spectrum analysis, but i need do it with the waveform. thanks!!
Re: how to export the waveform to the format *txt
Post by Gale Andrews » Sun Apr 06, 2014 3:50 pm
jimena wrote:i only can export to the format *txt when i´m in spectrum analysis, but i need do it with the waveform. thanks!!
The Frequency Analysis window is "modeless", so you can still access the waveform when that window is open, and can export audio.
What version of Audacity and operating system? See the pink panel at the top of the page.
If you want to export amplitude values for a selection of audio samples, use Analyze > Sample Data Export: http://manual.audacityteam.org/o/man/sa ... xport.html .
If you want to export labels, that is in the File Menu.
