record can't be great read with telephone's speaker
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
daviddu13200
HI
after the actalisation of audacity my record can't be great read with telephone's speaker only with phone head and after no problems with 2.0.3 what can i do to have my last song read correctely
Re: record can't be great read with telephone's speaker
This board is intended ONLY for general feedback and discussion about Audacity 2.X.
What sort of computer do you have?
What do you mean "telephone speaker"?
What do you mean "phone head"?
daviddu13200
I have a mobile computeur 2GHz RAM 4G The reading makes correctly everywhere ecxept on high speaker of the mobile phone (noise of computer instead of soundtracks) but well with a headphones
What sort of mobile computer?daviddu13200 wrote:I have a mobile computeur
What operating system are you using?
Which version of Audacity? (look in "Help > About Audacity")
daviddu13200
The version with problems was the new 2. just after the 1. but the problem had stop with the next 2;03 and after the phones mobile are iphone 3, samsung player one, are they softwares whom can erase the problem. The configuration is the same 44100 32 BITS EXPORT IN 16 BITS WAVE 44100 with windows and winlame for mp3
I'm sorry but I don't understand your question.
Audacity does not run on an iphone. If your problem is with the iphone I suggest you ask Apple.
If your question is about Audacity, then you may do better asking on the French forum board as your question appears to be losing its meaning when translated into English.
The French forum board is here: http://forum.audacityteam.org/viewforum.php?f=7
daviddu13200
the probmlem is all song create with audacity 1;x 2.03 2.05 is great and can be read with high speaker of mobile phone but not with the 2.0.(0,1or2) may be in record of them and i try to find a solution to erase the problem to listen them on high speaker of mobile phone
- Quality Assurance
If the problem (whatever it is) is fixed in 2.0.5, I suggest you use 2.0.5. We will not apply fixes to old versions of Audacity.
