Taking the audio of webm files[SOLVED]
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
audiowebm
Post by audiowebm » Mon Oct 22, 2012 8:34 pm
Hi, I'm using Audacity 2.0.1 and it does not accept webm files. I want to be able to use the audio of webm files, the same way I do with mp4 and flv files.
Thanks
Re: Taking the audio of webm files
Post by steve » Mon Oct 22, 2012 10:27 pm
Audacity does not support webm files. You will need to use another program to convert the webm files into a support format (such as WAV).
See here for information about webm support: http://www.webmproject.org/tools/
Post by Gale Andrews » Tue Oct 23, 2012 4:49 am
audiowebm wrote:Hi, I'm using Audacity 2.0.1 and it does not accept webm files. I want to be able to use the audio of webm files, the same way I do with mp4 and flv files.
I would guess you are still using FFmpeg 0.5 which does not support WebM. Assuming you are on Windows or Mac, uprade to FFmpeg 0.6.2 from here http://manual.audacityteam.org/o/man/fa ... tml#ffdown which does support WebM.
audiowebm
Re: Taking the audio of webm files[SOLVED]
Post by audiowebm » Tue Oct 23, 2012 8:55 pm
Thank you, Gale Andrews. After installing the latest FFDshow (corrected: FFmpeg) for Audacity, I was able to work with webm files.
Post by Gale Andrews » Wed Oct 24, 2012 3:02 am
audiowebm wrote:After installing the latest FFDshow for Audacity, I was able to work with webm files.
OK, I marked the topic as "Solved". I assume you mean FFmpeg, not ffdshow, though that also now supports WebM.
audiowebm
Post by audiowebm » Fri Oct 26, 2012 1:11 am
Gale Andrews wrote: I assume you mean FFmpeg, not ffdshow
Yes, I meant FFmpeg. Thanks.
