Using Versions 2.0.2 & 1.2.6
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
camtechman
Post by camtechman » Thu Sep 06, 2012 4:43 am
Why can't I run Audacity 1.2.6 (my present version) as well as Audacity 2.0.2 ? Thereby allowing me the option to choose which version to use.
There are some features on 1.2.6 that I prefer but on downloading the new 2.0.2 version, it replaced the 1.2.6 one.
waxcylinder
Re: Using Versions 2.0.2 & 1.2.6
Post by waxcylinder » Thu Sep 06, 2012 8:15 am
You can have both - just override the default target directory for the instllation. (I have two old versions of 1.2 along with current releases and alpha test versions on my PCs). What you can't do is run two different versions of Audacity on the same computer at the same time.
You should be able to re-install 1.2.6 from the Legacy Downloads section of this page: http://audacityteam.org/download/
Post by steve » Thu Sep 06, 2012 11:21 am
camtechman wrote:There are some features on 1.2.6 that I prefer
As a point of interest, which features are they?
camtechman
Post by camtechman » Fri Sep 07, 2012 10:13 am
Steve,
I prefer the layout and access to some the features but that's minor compared to this problem (as posted on another of my threads):
http://forum.audacityteam.org/viewtopic ... 16&t=61409)
camtechman
Post by camtechman » Fri Sep 07, 2012 10:46 am
waxcylinder,
Thanks for that advice but, not being all that savy with computers, I don't know how to do that.
I went to install Audacity 2.0.2 and after it going through the first insallation steps: Language, License Agreement, etc it showed a panel where it showed where it would be saved to: C:ProgramFilesAudacity and at the side of that there was "Browse" tab.
When I clicked on the browse tab it gave lots of options but which of those do I save it to?
Cheers,
Tony
waxcylinder
Post by waxcylinder » Fri Sep 07, 2012 1:21 pm
camtechman wrote:I went to install Audacity 2.0.2 and after it going through the first insallation steps: Language, License Agreement, etc it showed a panel where it showed where it would be saved to: C:ProgramFilesAudacity and at the side of that there was "Browse" tab.
So now you've got 2.0.2 installed over 1.2.6 right.
So go to install 1.2.6 from the links I gave you - then when that pops up the save location as C:ProgramFilesAudacity just type 1.2.6 at the end of it
then you will 2.0.2 installed in C:ProgramFilesAudacity
and 1.2.6 installed in C:ProgramFilesAudacity 1.2.6
camtechman
Post by camtechman » Fri Sep 07, 2012 11:27 pm
OK,
I've just installed Audacity 1.2.6 as instructed: C:ProgramFilesAudacity 1.2.6 and it overwrites the already installed Audacity 2.0.2.
So I've tried it the other way round, now that 1.2.6 is already installed. I then installed Audacity 2.0.2 and that then overwrites the 1.2.6 version.
I've even tried a clean install, uninstalling Audacity and then installing 1.2.6 as instructed: C:ProgramFilesAudacity 1.2.6 and then installing 2.0.2 as: C:ProgramFilesAudacity 2.0.2 and it still overwrites the other.
I've tried doing it the other way round, after doing an uninstall. C:ProgramFilesAudacity 2.0.2 first, followed by C:ProgramFilesAudacity 1.2.6 and the same thing happens in each case, one overwrites the other.
I've even tried adding a back slash in the command, i.e: C:ProgramFilesAudacity2.0.2 & C:ProgramFilesAudacity1. 2.6 and going trough the same process but one keeps overwriting the other.
My brain hurts....... :(
camtechman
Post by camtechman » Fri Sep 07, 2012 11:47 pm
HOLD THE FRONT PAGE !!
I've overcome my problem.
Firstly the reason for wanting the option of having both versions on my system, as outlined in my previous post, was that I thought the new 2.0.2 version still carried the median line issue as did the 1.3 version.
I've now recorded some audio on the 2.0.2 version and the median line problem isn't there, so I'm happy to update to the 2.0.2 version as my sole source of Audacity.
Problem solved.
(Although it doesn't answer the "overwriting" issue but ..Hey...I'm not bothered now)
Many thanks for all your help, it's very much appreciated.
Cheers,
Tony
Post by Gale Andrews » Sat Sep 08, 2012 5:32 am
camtechman wrote:I've now recorded some audio on the 2.0.2 version and the median line problem isn't there, so I'm happy to update to the 2.0.2 version as my sole source of Audacity.
I'm afraid if you zoom in you will see the centre zero line is there. The only way not to see it is to use a Spectrogram view mode ( http://manual.audacityteam.org/o/man/tr ... pectrogram ) but you cannot see audio samples in that mode.
camtechman wrote:(Although it doesn't answer the "overwriting" issue but ..Hey...I'm not bothered now)
There should not be any overwriting if you install to different folders.
You can right-click over the installed 2.0.2 audacity.exe > Send to Desktop and create a shortcut to that version.
Do the same for 1.2.6, then launch the version you want by double-clicking its shortcut on the Desktop.
camtechman
Post by camtechman » Sat Sep 08, 2012 12:02 pm
Hi Gale,
Therein lies the problem.
To do what you suggest is asuming that I can install both versions first.
I can't, what ever version I have initially installed gets overwitten by the other version I install after that.
So, I can get to the stage of having two versions to choose from as I only get one version - the latter one I install.
