Export and Export Multiple - "current location" option
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
pshute
Post by pshute » Sat May 26, 2012 9:43 pm
Both Export and Export Multiple remember the last location that one exported to. (I'm using the Windows version.)
This is useful, but sometimes it's also useful to export to the same folder as the current project, or a subfolder of it. Often it can be time consuming to navigate from the last exporting location to the current project file's folder. I think it would be handy to have a button to change the selected location to the current project's folder.
An example of another program that can do this is Irfanview's Batch section.
Re: Export and Export Multiple - "current location" option
Post by Gale Andrews » Sun May 27, 2012 2:25 am
I added your vote.
Thanks
pshute
Post by pshute » Sun May 27, 2012 4:56 am
Gale Andrews wrote:I added your vote.
Thanks
I take it this has been discussed before. Sorry, I couldn't find it. Can you provide a link to it, please?
Post by Gale Andrews » Sun May 27, 2012 5:05 am
Thanks
That actual solution hasn't been discussed before (as far as I know), but there are lots of opinions and proposed solutions about where export and save project should default to.
The vote I added is here http://wiki.audacityteam.org/wiki/Featu ... ing_Tracks .
The most "popular" solution is to have a Preference "Export to directory from which original .aup or audio file loaded: (like Save Project does). Should apply to all export options (including labels, which should use name of the file, not "labels.txt") and fall back to "last used" directory otherwise. (15 votes) "
pshute
Post by pshute » Sun May 27, 2012 5:47 am
Gale Andrews wrote:That actual solution hasn't been discussed before (as far as I know), but there are lots of opinions and proposed solutions about where export and save project should default to.
Thanks, it's actually further down at http://wiki.audacityteam.org/wiki/Featu ... references.
What does "fall back to ..." mean? That implies that the first choice of location could be somehow not available, but I don't see how that could happen. Or does it mean that "last used directory" is the other possible choice in a preference setting?
If the latter then I don't think this belongs in a preference. Both locations ("current" or "last") are both so useful that both should always be easily available, which is why I suggested a button on the form instead.
Post by steve » Mon May 28, 2012 2:16 am
pshute wrote:That implies that the first choice of location could be somehow not available, but I don't see how that could happen.
Quite easily. For example if you imported a file from a CD-R or any other non-writable location.
pshute
Post by pshute » Mon May 28, 2012 2:36 am
steve wrote:Quite easily. For example if you imported a file from a CD-R or any other non-writable location.
That makes sense. Well, I'm in favour of the preference option - better than no choice at all - but like I said, I think it's better to be able to choose one or the other at file saving time.
I agree that label export files should have the same name as their project too.
Post by Gale Andrews » Mon May 28, 2012 4:41 am
The link I gave was to what you asked for "Button to export to current project location".
A preference "Export to directory from which original .aup or audio file loaded" would I assume be a checkbox. A very simple case where it would "fall back" to the last directory exported to even if checked would be if you launched Audacity then made a recording and exported it. If unchecked, the export directory would always be the last used, as now.
I am not sure that Preference and your button are very compatible. Your button may be useful if you have that Preference unchecked, but often pointless if you have the Preference checked. The button would I assume either be greyed if there was no saved project open, or if active without a saved project would point to the directory that would be presented if you pressed File > Save Project.
pshute wrote:I agree that label export files should have the same name as their project too.
OK then I can add your vote for "Label Export: Include project name in exported file name: for example: projectname_labels.txt (1 votes)".
Do you still want to vote for a Preference "Export to directory from which original .aup or audio file loaded"? It's up to you. The votes are only an indication for the developers. A number of different methods of achieving some end may be on Feature Requests but be partly conflicting.
