Export 320kbps
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
Metaliman
Export 320kbps
Post by Metaliman » Tue Apr 03, 2012 1:05 pm
Hi,
i'm searching since a while how to export MP3 songs into 320kbps quality on Audacity 2.0.0 but I still didn't find anything, I searched several times, checked everywhere on Internet but nobody seems to talk about it.
The sounds are automaticly registered at 180kbps quality without possibility to set it as on previous versions, now my problem is that previous versions shuts down after clicking on the "stop" button (at least with win7 64bit), so I still can't record anything.
Maybe someone could help me.. Thanks in advance
Greetings
Re: Export 320kbps
Post by steve » Tue Apr 03, 2012 1:21 pm
Metaliman wrote:now my problem is that previous versions shuts down after clicking on the "stop" button (at least with win7 64bit), so I still can't record anything.
Please check in the "Help menu > About Audacity" and say exactly which version you are using.
For changing the MP3 settings (assuming that you are using Audacity 2.0 Unicode) see here: http://manual.audacityteam.org/man/MP3_Export_Options
Metaliman
Re: Export 320kbps
Post by Metaliman » Tue Apr 03, 2012 2:05 pm
aah I didn't even notice the "option" button on the right -.-
Thanks for the help! :)
