Blank samples in web cam mic recording @384k
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux.
Please state:
Permanent link to this post Posted by smokingwheels » Wed Jan 24, 2018 3:24 am
Lubuntu 17.10 4GB Core2Duo 1.4 GHz Laptop
Audacity 2.2.1 @384k samples/sec
Distribution release.
After recording and processing to restore old wornout tape there is clicks similar to a record with lots of dust at regular random times. See Att.
There are minor flat spots in the recording.
Am I pushing my old Laptop too fast eg the sample rate?
Information stored on a NextCloud. (Temporary)
Rawdata
https://gsw.undo.it/index.php/s/Wb5sq9ClUk3ah3O
after Eq
https://gsw.undo.it/index.php/s/kV8TOHxRXHZJKdu
Screenshot before and after processing
Screenshot from 2018-01-24 10-29-01.png (173.89 KiB) Viewed 551 times
Rawdata.wav
Recording sample
(2.9 KiB) Downloaded 9 times
aftereq.wav
After Equalization sample
(101.76 KiB) Downloaded 8 times
smokingwheels
Re: Blank samples in web cam mic recording @384k
Permanent link to this post Posted by steve » Wed Jan 24, 2018 11:01 am
Try dropping the sample rate down to 44100 or 48000. Use whichever works for you best (they both have a frequency bandwidth that far exceeds old tape).
Permanent link to this post Posted by smokingwheels » Wed Jan 24, 2018 11:27 am
Thanks Steve I will give it a go soon.
smokingwheels
Return to GNU/Linux
Who is online
