I am recording vinyl records.
I am trying to set the recording level to avoid clipping (aiming for -6 dB). Documentation says the blue bar in the Recording meter indicates maximum level reached, so I play tracks (without recording) and activate the meter, after having reset the blue bar by left-clicking on the meter. I am controlling the source level through my pre-amplifier and through the "Recording" panel in pavucontrol.
The recording meter seems to work correctly, except the levels shown never go beyond -6 dB (idem for the blue bar), even if I boost the source volume to a point where the sound is obviously distorted.
Am I misreading the documentation, or is there another way to play a sample and find out whether the source sound level is ok, by obtaining the maximum level that was reached?
Audacity 2.2.1
Alsa / PulseAudio
Archlinux 4.14.13-1-ARCH #1 SMP PREEMPT x86_64 GNU/Linux
Recording meter blue bar never goes beyond -6 dB
Please state:
Please state:
fortiernor
- Operating System: Linux Debian
fortiernor
Re: Recording meter blue bar never goes beyond -6 dB
I found a workaround, which is to disable pulseaudio temporarily.
Start Audacity with:
In Preferences, host is Alsa; set playback and recording device to the appropriate device, in my case it was
and
respectively (integrated sound on the motherboard, input plugged into line in).
So it is probably an issue with Audacity and PulseAudio.
Code: Select all
$ pasuspender -- audacityCode: Select all
HDA intel PCH: ALC892 Analog (hw0,0)Code: Select all
HDA intel PCH: ALC892 Analog (hw0,0): Line: 0So it is probably an issue with Audacity and PulseAudio.
