glitches and random skipping starting/stopping playback
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux.
Please state:
Permanent link to this post Posted by senorsmile » Wed Jan 17, 2018 7:00 am
I have a new Lenovo p51s with 32 GB ram running Ubuntu 16.04.
Audacity v2.1.2.
I am having trouble playing back audio. The issue is hard to explain, but I will attempt to do so. It happens on multiple different audio files, and multiple types of audio files.
Initially starting an audio file is fine. If I stop and then start the audio again, it has this glitch (like a very short static sound) followed by a jump of 1-10 seconds then starts playing again.
If I stop and start a few more times, it gets worse, to the point that it just glitches and stops playing altogether. I will have to hit play several times.
This is especially noticeable when a specific section of audio is selected, and I'm trying to play it in a loop. The entire audio plays once, I hit play to play it again, and it skips all around, glitches a lot, and sometimes just doesn't play anything (except a quick glitch).
senorsmile
Return to GNU/Linux
Who is online
Users browsing this forum: No registered users and 2 guests
