Hey guys,
trying to use monitoring from a line in for a USB DAC I have connected to my Pi, all plunged in can see the card ect. But its not getting any sound?
No visible input at all?
Shane
Line in not working Raspian USB DAC
Please state:
Please state:
Re: Line in not working Raspian USB DAC
Audacity is not officially supported by the Raspberry Pi, though there have been a few reports of it working to some degree (no-one is claiming great performance
I'd suggest breaking it down into smaller, simpler tasks. Try to get arecord to work first. When that is working, then move on to Audacity.
