need speed
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux.
Please state:
Contact:
Re: need speed
Post by steve » Fri Jul 21, 2017 3:58 pm
autodctr wrote:I want to at least get a feel for what I am doing before hauling it out to church and swapping out the other machine.
Very wise ;)
autodctr wrote:I started Jack
How did you do that?
I usually use "QjackCtl" (Jack Audio Connection Kit) for configuring, starting and stopping Jack.
If your system is going to always be used with Jack, then it will probably be more convenient to configure the system to start Jack on log-in, but QjackCtl is very convenient for testing the set-up and getting everything working.
autodctr wrote:I opened Jack
Not sure what you mean. "Jack" is a service, not an application. Jack itself does not have a graphical interface.
If Audacity shows "Jack" in Preferences, then Jack is running.
Ensure that Jack is selected as the "host" in the device toolbar. Normally you would want the recording and playback devices set to "System". Then try playing something. If it plays with those settings, then it's working.
autodctr
Re: need speed
Post by autodctr » Fri Jul 21, 2017 4:12 pm
I started Audacity and selected Jack on everything I could find under Preferences. However, Audacity is showing a high level of sound output, but there is no sound from the speakers. What did I screw up?
autodctr
Re: need speed
Post by autodctr » Fri Jul 21, 2017 4:15 pm
OK: got sound now. In the window that opens when I click on the Jack icon, do I have to do anything in that window before opening Audacity?
autodctr
Re: need speed
Post by autodctr » Fri Jul 21, 2017 4:21 pm
Rebooted machine and Jack is not running. How do I make it run on start-up?
Contact:
Re: need speed
Post by steve » Fri Jul 21, 2017 6:40 pm
autodctr wrote:How do I make it run on start-up?
The hard bit first: Work out what command line options you need to start Jack.
Try
Code: Select all
jackd -r -d alsa -r 44100
If that fails, try:
Code: Select all
jackd -r -d alsa -r 44100 -P
If that fails, check the Jack manual:
Code: Select all
man jackd
and / or Jack help:
Code: Select all
jackd --help
and / or
Code: Select all
Google.com
Contact:
Re: need speed
Post by steve » Fri Jul 21, 2017 6:42 pm
Once you have Jack starting reliably from the command line, add that command to your start-up items (on my system it's called "Session and Startup")
autodctr
Re: need speed
Post by autodctr » Wed Jul 26, 2017 3:53 pm
Alright. I didn't bother trying to get Jack to run on boot. Instead, I made a picture to use as wallpaper that says in big letters: Start JACK. (Much easier. :-) )
I tried recording 2 channels and it worked just fine. I am going to try later to output via USB cable from one computer to another. If I can get that to work, I have several 18 channel recordings that I can try.
Got a question though. You said to make sure everything runs the same sampling rate. I know where to choose that in Audacity, but I don't know where that is in Jack. Also, what sampling rate should I be using?
Contact:
Re: need speed
Post by steve » Wed Jul 26, 2017 4:23 pm
autodctr wrote: I didn't bother trying to get Jack to run on boot. Instead, I made a picture to use as wallpaper that says in big letters: Start JACK.
:D
If that works for you, then why not!
If you use QjackCtl to start Jack, the sample rate settings are in the "Setup" dialog (click the Setup button).
The most "standard" sampling rate is 44100 Hz. That's what audio CDs use and it's the default in Audacity. It's probably the default for Jack.
44100 is a good choice unless you have a specific reason to use something else (for example, I know of one USB mic that frequently has problems unless running at 48000 Hz, but that's unusual).
autodctr
Re: need speed
Post by autodctr » Sun Jul 30, 2017 3:51 pm
Again, there is no joy. It is still doing the exact same thing with Jack handling everything. About every 2 minutes, a buzzing noise fades in on all 18 channels, lasts about 20 seconds and then fades out. 2 minutes later, same thing.
Contact:
Re: need speed
Post by steve » Sun Jul 30, 2017 4:21 pm
Is the buzzing accompanied by a huge number of xruns reported in QJackCtl?
Did you ever tell us what the device is that you are recording with?
