need speed
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux.
Please state:
autodctr
Re: need speed
Post by autodctr » Sun Jul 09, 2017 6:24 pm
I have not. Anytime I have ever tried using JACK, I have never had good luck. However, I have not tried it using Audacity.
I still believe that what I am trying to do is just too much info to be processed and written to disc that quickly. The older version of Audacity wrote to the disc differently than the newer version. What I probably need is a Dante card, but that is not in my budget.
Contact:
Re: need speed
Post by steve » Sun Jul 09, 2017 6:47 pm
autodctr wrote:I still believe that what I am trying to do is just too much info to be processed and written to disc that quickly.
The amount of data being written has not changed much. The vast majority of the data is the 32-bit PCM "AU" data files, then there's a tiny bit of data in the AUP file. Audacity has been using the same format for AU files for many years.
I've just tested recording 20 channels simultaneously using Jack, Audacity 2.1.3, a spinning hdd, an i7 processor laptop with 8 GB RAM.
The waveform updates a bit sluggishly with waveform data appearing about every 3 seconds, but the recording is perfect. If a spinning hdd can handle 20 tracks at 44100 Hz sample rate, 32-bit float format, then it should be no problem at all for you SSD. (I've also tested recording onto a SSD and that also works flawlessly, though recording length for 20 tracks is limited by my SSD being quite small capacity).
Contact:
Re: need speed
Post by steve » Sun Jul 09, 2017 6:49 pm
You do need to avoid on-the-fly resampling while recording a lot of tracks, otherwise you either compromise quality due to low quality conversion, or sacrifice performance due to high quality conversion. Ensure that you use the same sample rate throughout.
autodctr
Re: need speed
Post by autodctr » Sun Jul 09, 2017 7:32 pm
You have my interest now. Are you using JACK? What are you changing in the "out-of-the-box" Audacity setup? Realize (and you probably already do) that the stream coming in is purely digital: straight out of a Allen & Heath QU32 mixer. It comes in via a USB cable directly to a USB port on the PC. It does not go to the sound card or any other card.
I do not know how Audacity records the data. What I do know is that when I used the old Audacity (2.0.?), when I hit the STOP button to stop the recording, I would have to wait for 1 to 1.5 minutes before I was able to click on FILE and name and save the file. While waiting this time, the HD light was on solidly. When the light went off, I could save the file. But, with the new Audacity 2.1.2, as soon as I stop the recording, I can instantly hit the FILE icon and save the file. So, there is something different that Audacity is doing in writing / saving the file. It worked before: all 18 channels with no problem, but it doesn't now. What happens now is that about every 2 minutes, I get this buzzing noise across all channels. It lasts about 20 seconds and then clears itself only to repeat again about 2 minutes later.
autodctr
Re: need speed
Post by autodctr » Sun Jul 09, 2017 7:33 pm
I just saw where you said that you did use JACK. Why is that making a difference?
Contact:
Re: need speed
Post by steve » Sun Jul 09, 2017 8:15 pm
autodctr wrote:Realize (and you probably already do) that the stream coming in is purely digital: straight out of a Allen & Heath QU32 mixer. It comes in via a USB cable directly to a USB port on the PC.
In effect, the QU32 is a (very large) external sound card. Your computer has no idea that it is a mixing desk. All that your computer sees is a multi-channel USB audio device. Your computer knows that it is an audio device rather than some other type of USB device, because ALSA (the audio device driver) tells the Linux kernel that it is an audio device and handles data transfer between the device and the sound system's application interface.
By default, most modern Linux desktop distributions use PulseAudio as the default sound system. PulseAudio offers many benefits, such as on-the-fly resampling, device sharing, audio stream mixing, and more. However, this does come with a price of processing power.
To use Jack audio system it is necessary to bypass PulseAudio. Jack requires exclusive access to the audio device and everything has to run at the same sample rate (no resampling). Whereas PulseAudio will start and stop audio streams on demand, when you start Jack, it starts its audio streams and runs them continuously. Applications are then 'patched in' to those streams. Once the streams are running, there is virtually zero overhead for applications connecting to the audio streams. The efficiency of Jack is comparable to that of ASIO on Windows, with the addition of powerful audio routing capability similar to, but more flexible than Rewire.
When recording into a new project, Audacity writes the audio data into its temp folder. On saving the project, data that is in use by the current state of the project is copied from the temp folder into the project "_data" folder. On closing the project, unused data (the "Undo" history) is deleted.
When recording into a project that has been saved, Audacity writes the audio data directly into the project's "_data" folder. Saving a project that has previously been saved is very much faster because no data needs to be copied - the data is already in the project "_data" folder. On closing the project, unused data is deleted from the "_data" folder.
autodctr
Re: need speed
Post by autodctr » Sun Jul 09, 2017 10:42 pm
Thank you so much for explaining that. Before I (we, if you are willing) go further, can we continue this here or do I need to contact you some other way?
This system is used at my church, so even though I have access to it anytime that I want, I do not have access to guitars, drums, keyboards, and singers except on Sundays and a few other times. So, anything to be tried will usually only happen one day a week. I run the sound room for 2 of 3 services. First service is for making sure that the sermon is recorded and uploaded to the website. With the new version of Audacity, I am doing that via analogue hook-up, which is fine. However, once I have that done, I have the second service to experiment with recording the 18 channels of music.
So, I am assuming that the next thing that I need to do is install JACK. What do I need to specifically do? I kinda remember an awful lot of questions during the install of JACK. I also remember pretty much screwing my system up to where I just reinstalled it.
Again, thank you for your help so far: you have no idea how much it is appreciated.
Contact:
Re: need speed
Post by steve » Sun Jul 09, 2017 11:47 pm
autodctr wrote: can we continue this here
Here is best for me.
Jack should already be installed unless you built Audacity from the source code without Jack support. Jack is normally a dependency. By default it does not start on log-in, so you need to start it manually (can be scripted later when everything is running properly.
Assuming that you have a fairly standard Xubuntu installation, the default sound system will be PulseAudio, and PulseAudio Volume Control (pavucontrol) should already be installed.
If you run:
Code: Select all
sudo apt-get install pavucontrol
it will either tell you that it is already installed, or it will install it. Either way it is helpful to have it installed.
For configuring and starting Jack, install QjackCtl
So that Jack will play nicely with Pulse, install pulseaudio-module-jack
Code: Select all
apt-get install qjackctl pulseaudio-module-jack
Then configure qjackctl to run the following command after startup. Copy it into "Setup..." > "Options" > "Execute script after Startup":
Code: Select all
pactl set-default-sink jack_out
IMPORTANT - Ensure that no audio applications are running while you set this up or the set-up will fail.
It's a good idea to reboot or at least log out and back in again to ensure that all sound services are 'fresh'. Jack MUST have exclusive access to the audio device.
Now you need to set up the options in QjackCtl so that Jack uses the correct audio device (your USB mixer).
After selecting the input and output devices, try starting the Jack server by clicking the "Start" button in the main interface of QjackCtl. If Jack fails to start (quite likely) you will need to fiddle with the Sample Rate, Frames and Buffers settings to get it to run. Don't aim for minimum latency - aim for maximum stability.
Once you manage to get Jack to run (without "xruns") then that's the hard part done.
Let me know how you get on.
autodctr
Re: need speed
Post by autodctr » Mon Jul 10, 2017 10:14 am
I will keep you updated because I am sure that I will have questions along the way. I will try and get out to the church in the next day or 2 and bring the machine home to play with.
autodctr
Re: need speed
Post by autodctr » Fri Jul 21, 2017 3:46 pm
Alright: finally got back to this thing after a very busy week.
I started Jack and put that line in to run after start-up. I opened Audacity and under Preferences set it to use Jack. I opened Jack and have a little window sitting on the desktop. Now, I am lost. Do I have to hit the Play button in Jack or will Audacity handle that for me? How can I test this at home: I want to at least get a feel for what I am doing before hauling it out to church and swapping out the other machine.
