Editing [SOLVED]
Please state:
James3
Editing [SOLVED]
Post by James3 » Sat Jan 14, 2017 7:58 am
Hi
(sorry...I am french!)
I just installed Audacity and record from a tape recorder successfully (it's appear!) Then I have registered the project in my repertory.
My problem is I can't read it. I start with the "green arrow", the barre translante normally reading de project but no sounds producted from PC!
What i have to adjust to obtain result?
Thanks
Re: Editing
Post by steve » Sat Jan 14, 2017 12:32 pm
Ensure that you have the correct playback device selected in the device toolbar.
James3
Re: editing [SOLVED]
Post by James3 » Sat Jan 14, 2017 3:10 pm
Thanks
Sincèrement m'y Last message. I visited the tool barre and found the connection to the source was not correct
Now it's OK
Thanks
