Half speed playback on file from arecord
Please state:
tcostigl
Post by tcostigl » Fri Jan 13, 2017 2:30 pm
Hello,
I am trying to play back a wav generated with the arecord command. I do:
Code: Select all
arecord > test.wav
Recording WAVE 'stdout' : Unsigned 8 bit, Rate 8000 Hz, Mono
When I open this file with audacity and play it, it sounds like it is playing back at half speed. The Project Rate is set to 8000 Hz. How can I make it play back normally? The aplay command plays it correctly.
Re: Half speed playback on file from arecord
Post by steve » Fri Jan 13, 2017 3:34 pm
Which version of Audacity?
Which version of Linux?
How exactly did you "open" the test.wav file?
Do other files play correctly in Audacity?
Have you tried rebooting your computer?
tcostigl
Post by tcostigl » Sat Jan 14, 2017 4:04 pm
steve wrote:Which version of Audacity?
2.1.2
Ubuntu 16.04. It also plays back half speed on windows.
File -> Open -> "Make a copy"
The wavs downloaded from http://www.music.helsinki.fi/tmt/opetus ... dex-e.html play back fine.
Yes.
Does playing back files from arecord work fine for you? Maybe the recording device is not actually recording in the format it says or is broken in some other way?
Post by steve » Sun Jan 15, 2017 12:51 pm
tcostigl wrote:Does playing back files from arecord work fine for you?
Yes.
tcostigl wrote:Maybe the recording device is not actually recording in the format it says or is broken in some other way?
You can check that with "MediaInfo". It should be available in the Ubuntu repository (the GUI version is probably easiest to use).
