Run audacity from console to work on multiple files on serve
Please state:
arizona
Post by arizona » Wed Jan 04, 2017 8:13 pm
Hi all,
I am using Ubuntu Server 14.04
I want to do the following:
* I have audio files in folder A
* I want to run a program (audacity) from console on the server, which takes audio files from folder A and applies a defined set of filters (compression, normalization, echo, bass effect)
* Then save the files to folder B
Is there any possibility to do this with audacity, or any other software?
Awaiting your suggestions!
Thanks!
Re: Run audacity from console to work on multiple files on s
Post by steve » Wed Jan 04, 2017 8:26 pm
Audacity is very GUI orientated. For command line use, have a look at SoX http://sox.sourceforge.net/
