Chains and resampling [SOLVED]
Please state:
westwind
Post by westwind » Tue Nov 08, 2016 8:39 pm
Is it possible yet? Can I add resampling to a chain to batch convert a large batch of audio files to 22050 sample rate?
Re: Chains and resampling
Post by steve » Tue Nov 08, 2016 9:09 pm
Not with Audacity, but there are other programs that can, such as SoX.
There's an example bash script for batch processing with SoX here that may help: http://forum.audacityteam.org/viewtopic ... 51#p214951
westwind
Re: Chains and resampling [SOLVED]
Post by westwind » Wed Nov 09, 2016 9:49 am
Thankyou Steve - for pointing me to sox - hadn't used it before and thanks for that sox-recursive-batch-converter script: it whizzed through 1189 mp3 files and (being slightly modified*), reduced volume and bit rate as well as the resampling. Delighted - thankyou.
* sox -S -v 0.5 "$FILE" -r 22050 -C 24.2 "$DIR/$outputfile"\
Reason: marked SOLVED
