Audacity Crashes When Every Time Start Monitoring?
Please state:
Please state:
Its a clean install. Was going through the online tutorial step by step, and when we go the part where it said to Start Monitoring in the Recording Meter, the program just crashes; every single time. Im completely clueless. I just want something to make simple voice recordings for screencasts.
Re: Audacity Crashes When Every Time Start Monitoring?
Which version of Linux?
Which version of Audacity?
What are you trying to record from?
Please post the FULL contents of "Audacity Help menu > Audio device info" in your reply.
Linux Mint 17.3 (Rosa)
Audacity 2.0.5
The mic on my headset
This what you wanted?:
Audacity 2.0.5
Code: Select all
Default capture device number: 17
Default playback device number: 17
Device ID: 0
Device name: HDA ATI SB: ALC892 Analog (hw:0,0)
Host name: ALSA
Input channels: 2
Output channels: 8
Low Input Latency: 0.005805
Low Output Latency: 0.005805
High Input Latency: 0.034830
High Output Latency: 0.034830
Supported Rates:
44100
48000
96000
192000
Device ID: 1
Device name: HDA ATI SB: ALC892 Digital (hw:0,1)
Host name: ALSA
Input channels: 0
Output channels: 2
Low Input Latency: -1.000000
High Input Latency: -1.000000
Supported Rates:
32000
44100
48000
88200
96000
192000
Device ID: 2
Device name: HDA ATI SB: ALC892 Alt Analog (hw:0,2)
Host name: ALSA
Input channels: 2
Output channels: 0
Low Output Latency: -1.000000
High Output Latency: -1.000000
Supported Rates:
Device ID: 3
Device name: HDA NVidia: HDMI 0 (hw:1,3)
Host name: ALSA
Input channels: 0
Output channels: 8
Supported Rates:
32000
44100
48000
88200
96000
176400
192000
Device ID: 4
Device name: HDA NVidia: HDMI 1 (hw:1,7)
Host name: ALSA
Input channels: 0
Output channels: 2
Supported Rates:
32000
44100
48000
96000
Device ID: 5
Device name: HDA NVidia: HDMI 2 (hw:1,8)
Host name: ALSA
Input channels: 0
Output channels: 8
Supported Rates:
32000
44100
48000
88200
96000
176400
192000
Device ID: 6
Device name: sysdefault
Host name: ALSA
Input channels: 128
Output channels: 128
Low Input Latency: 0.021333
Low Output Latency: 0.021333
High Input Latency: 0.021333
High Output Latency: 0.021333
Supported Rates:
8000
9600
11025
16000
22050
32000
44100
48000
88200
176400
352800
Device ID: 7
Device name: front
Host name: ALSA
Input channels: 0
Output channels: 8
Supported Rates:
44100
48000
96000
192000
Device ID: 8
Device name: surround40
Host name: ALSA
Input channels: 0
Output channels: 8
Supported Rates:
44100
48000
96000
192000
Device ID: 9
Device name: surround41
Host name: ALSA
Input channels: 0
Supported Rates:
44100
48000
96000
192000
Device ID: 10
Device name: surround50
Host name: ALSA
Input channels: 0
Supported Rates:
44100
48000
96000
192000
Device ID: 11
Device name: surround51
Host name: ALSA
Input channels: 0
Output channels: 8
Supported Rates:
44100
48000
96000
192000
Device ID: 12
Device name: surround71
Host name: ALSA
Input channels: 0
Output channels: 8
Supported Rates:
44100
48000
96000
192000
Device ID: 13
Device name: iec958
Host name: ALSA
Input channels: 0
Output channels: 2
Supported Rates:
32000
44100
48000
88200
96000
192000
Device ID: 14
Device name: spdif
Host name: ALSA
Input channels: 0
Output channels: 2
Supported Rates:
32000
44100
48000
88200
96000
192000
Device ID: 15
Device name: pulse
Host name: ALSA
Input channels: 32
Output channels: 32
Low Input Latency: 0.008707
Low Output Latency: 0.008707
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Device ID: 16
Device name: dmix
Host name: ALSA
Input channels: 0
Output channels: 2
Supported Rates:
48000
Device ID: 17
Device name: default
Host name: ALSA
Input channels: 32
Output channels: 32
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Selected capture device: 17 - default
Selected playback device: 17 - default
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Available mixers:
Available capture sources:
0 - Front Mic:0
1 - Rear Mic:0
2 - Line:0
3 - Front Mic:1
4 - Rear Mic:1
5 - Line:1
Available playback volumes:
0 - Master:0
1 - Headphone:0
2 - PCM:0
3 - Front:0
4 - Front Mic:0
5 - Front Mic Boost:0
6 - Surround:0
7 - Center:0
8 - LFE:0
9 - Side:0
10 - Line:0
11 - Line Boost:0
12 - Rear Mic:0
13 - Rear Mic Boost:0
Capture volume is native
Playback volume is native
Reason: code tags added for readability
That's a very old version. I'd suggest that you check for updates.crossgear wrote:Audacity 2.0.5
In the device toolbar, try selecting "HDA ATI SB: ALC892 Analog (hw:0,0))" as both the recording and playback device. You may need to drag the device toolbar wider so that you can see the "hw:0,0" as you have several options with very similar names.
