Code: Select all
sudo apt-get install audacityCode: Select all
sudo apt-get install audacityNo; I was playing with editing a song that was opened via Audacity. However, the problem turned out to be that my internal mic was muted, and that somehow blocked the audio. (?) Thanks everyone for your help!If you want to use other audio applications while using Audacity, choose the "default" or "pulse" playback device in Audacity.
Are you trying to record over a song playing in rhythmbox, or something else?
