Wayland support
Please state:
havill
Operating System: OS X 10.6 Snow Leopard or earlier
Wayland support
Post by havill » Sat Oct 15, 2016 12:49 pm
Due to its superior performance and other issues, Wayland on GNOME is set to become the default Window Manager for Fedora 25 (the next version).
However, Audacity 2.1.2 crashes on startup if the windowing system is Wayland. If the windowing system is classic X then it works okay.
Is there a timeline for getting it to work with Wayland? Most other major programs (web browsers, libre office, etc) work fine with Wayland.
Re: Wayland support
Post by Gale Andrews » Sat Oct 15, 2016 1:24 pm
As you say, https://bugzilla.redhat.com/show_bug.cgi?id=1346040#c1.
Also Audacity does not support gtk3 so you may encounter https://bugzilla.redhat.com/show_bug.cgi?id=1347053.
