Slow down tempo without losing sound quality
Please state:
proton43
Post by proton43 » Fri Oct 07, 2016 8:40 pm
Hello,
Probably this question is already answered, but I didn't find answers, so i keep looking.
Is there a way to slow down tempo (from my experience tempo change is speed change compensated with pitch change, right?) without getting distortion?
Do I miss something?
Thanks!
Trebor
Re: Slow down tempo without losing sound quality
Post by Trebor » Sat Oct 08, 2016 7:01 am
proton43 wrote:... Is there a way to slow down tempo (from my experience tempo change is speed change compensated with pitch change, right?) without getting distortion?
There are two native effects in Audacity which can change tempo without changing pitch :
Change Tempo & Sliding Time Scale / Pitch Shift.
Each effect adds a different type of distortion. IMO the second type is least offensive with music.
proton43
Post by proton43 » Sat Oct 08, 2016 9:09 am
But there's totally no option of losslessly slowing down tempo?
Post by Gale Andrews » Sat Oct 08, 2016 1:40 pm
proton43 wrote:But there's totally no option of losslessly slowing down tempo?
No because when you slow audio down, the laws of audio dictate that it *should* reduce pitch. If you don't slow down too much, Sliding Time Scale will not sound too bad.
