"If the waveform is flat topped at the the top (+1) and bottom (-1), turn the recording level down. "
I'll try this.
Thank you for your reply, Gale.
Problem while Recording a Vinyl Record [SOLVED]
Please state:
Please state:
Re: Problem while Recording a Vinyl Record [SOLVED]
Turning down the volume in the pre-box solved the problem, even though i don't know why.
Thank you, Gale
Thank you, Gale
