i cant decrease the input volume on the audacity the bar is grayed and its up to max
how can i fix that
system ubentu
input volume bar
Please state:
Please state:
abushalbak
- Operating System: OS X 10.9 Mavericks
Re: input volume bar
Adjust the recording level using "PulseAudio Volume Control".
If you don't already have that installed, it's available in the Ubuntu repository and is called "pavucontrol".
