Cleaning up old demos with Audacity 2.0.5
Please state:
analog
Post by analog » Thu Aug 18, 2016 3:45 pm
I've got some old Van Halen demos from 1973-1976, and I've been trying to remove their metallic, tinny sound and plastic drum sound. I am also trying to make the vocals louder. To be precise, I am working with this, which I downloaded as an MP3 stereo file. I have been using noise removal, normalisation, the compressor and boosting the bass, and so far, so good. But I need help on removing the metallic old sound and improving the quality.
Re: Cleaning up old demos with Audacity 2.0.5
Post by kozikowski » Fri Aug 19, 2016 3:43 am
The metallic sound is a combination of permanent compression distortion and what is probably fake stereo processing permanent distortion.
We're very clear that we can't take processing out of a performance. That's why we require voice performers to give us raw capture clips, not post production fails.
Is it possible to get work closer to the original?
Trebor
Post by Trebor » Fri Aug 19, 2016 12:31 pm
analog wrote:... I am also trying to make the vocals louder ...
Make an in-sync duplicate of the original track, [Ctrl+D], then apply isolate vocals to the duplicate track, then mix that back with the original to boost the vocal volume.
You got a lot of work on your hands cleaning up the percussion ...
'age sixteen' before-after Audacity.flac
(1.37 MiB) Downloaded 50 times
[ You'll need Audacity's spectral edit tool for that ].
