Running 2.1.2 on Mint 18, I installed lame, but now I can't find "Libraries Preferences" in the "Edit Preferences" menu so I can point to it.
Thanks for any advice....Lyle
can't find "Libraries Preferences" to add lame [SOLVED]
Please state:
Please state:
- Quality Assurance
Re: can't find "Libraries Preferences" to add lame
If you are using a repository 2.1.2 provided by Mint, they have probably already linked MP3 encoding and FFmpeg (or Libav) dynamically to the relevant system libraries. If they do that, they remove the Libraries preferences because they are redundant, and you can just go ahead and export MP3. Have you tried that?
Re: can't find "Libraries Preferences" to add lame [SOLVED]
That does seem to be the case: "Libraries Preferences" removed after installing using "apt-get", but it finds lame ok and exports an mp3
Thanks....Lyle
Thanks....Lyle
