integrate Audacity menu into Ubuntu Top Bar [SOLVED]
Please state:
orschiro
Post by orschiro » Sat Aug 06, 2016 7:38 am
Dear all,
Ubuntu supports the integration of an application's menu into the top bar [1].
How can I do the same with the Audacity menu on Ubuntu 16.04?
Mine is not integrated [2].
Thankfully,
~Robert
[1] https://i.kinja-img.com/gawker-media/im ... uj9jpg.jpg
[2] http://i.imgur.com/TQLdTWb.png
Re: How to integrate Audacity's menu into the Ubuntu Top Bar
Post by Gale Andrews » Sat Aug 06, 2016 11:31 am
orschiro wrote:Ubuntu supports the integration of an application's menu into the top bar [1].
See http://audacity.238276.n2.nabble.com/Au ... 75465.html.
orschiro
Re: integrate Audacity menu into Ubuntu Top Bar [SOLVED]
Post by orschiro » Sat Aug 06, 2016 1:43 pm
Thank you very much, Gale!
Your solution provided on the mailing list does work perfectly for me. :-)
Warmly,
~Robert
