Audacity suddenly won't open
Please state:
Please state:
briandc
- Operating System: OS X 10.7 - 10.8 Lion / Mountain Lion
Hi all,
until today, Audacity opened and ran just fine.
Tonight, opening for the first time, it gave a crash notice (see below). I opened it from the terminal and it still crashed. However, a crash report was created that involved a few different files. Where/how can I post this info for help?
Thanks!
brian
Thanks!
brian
- Quality Assurance
Re: Audacity suddenly won't open
Are you still using Audacity 2.1.2?
We can't tell anything from that screenshot. Please attach the generated ZIP file. It's in /tmp/. If you can't find it, make Audacity crash again and note the location of the ZIP file when Audacity tells you.
Please see here for how to attach files: http://forum.audacityteam.org/viewtopic ... 49&t=64936.
However if you added a plugin, it could be that.
And simply deleting the entire ~/.audacity-data/ folder to do a complete reset of your settings and registered plugins could get Audacity going again.
briandc
Hi Gale,
thanks for your post. I tried deleting the ~/.audacity-data folder and restarting, but still got the crash. I've attached the .zip file here.
Thanks!
brian
Thanks!
brian
- Quality Assurance
Where did this Audacity 2.1.2 come from, exactly? Did you build it yourself? Did you install it, if so, where? Where are you executing Audacity from?
It appears to be a permissions problem:
If you installed 2.1.2, open a new terminal window and just type15:45:06: Audacity 2.1.2
15:45:06: Error: Impossible to get permissions for file '/home/brian/.audacity-data/pluginregistry.cfg' (error 2: No such file or directory)
Code: Select all
audacityGale
briandc
I tried running from the terminal, and got this:
The version I'm running I got from the repositories (Ubuntu), version: 2.1.2-1
brian
Code: Select all
[email protected]:~$ audacity
(Audacity:10211): Gtk-WARNING **: gtk_disable_setlocale() must be called before gtk_init()
lo server running on 18886brian
- Quality Assurance
I don't know if the permissions error that was noticed is the cause or a symptom.
Have you installed KXStudio or JACK before the problem started?
You can also ask on the Ubuntu forums if there is any significance in the lo server message. I don't see that message launching Audacity on Ubuntu 14.04.
briandc
Yes, I installed the KXStudio repos before I had any problems. In fact, all was working perfectly fine with Audacity until just the other day. I really don't know what I did that would cause it to not open.
Perhaps I should try re-installing Audacity?
brian
brian
- Quality Assurance
You said you had already deleted the ~/.audacity-data folder, so it is not a settings problem.
Yes it's possible that uninstalling the 2.1.2 repository package then reinstalling it "might" fix the permissions problem, if that's what it is.
It could be that some KXStudio application that is running is causing the problem.
It could even be that to make Audacity work with KXStudio you need to actually start over. Get rid of Ubuntu 16.04 and install the KXStudio 14.04 distribution that comes with Audacity. I can't help you with that. You will need to contact Ubuntu or KXStudio.
briandc
Hi again,
I tried re-installing, and then I ran audacity in the terminal and got the following. Hope this helps to solve this --
brian
Code: Select all
audacity
(Audacity:5027): Gtk-WARNING **: gtk_disable_setlocale() must be called before gtk_init()
lo server running on 13256
*** Error in `audacity': double free or corruption (fasttop): 0x00007f57f0029050 ***
======= Backtrace: =========
/lib/x86_64-linux-gnu/libc.so.6(+0x77725)[0x7f5820408725]
/lib/x86_64-linux-gnu/libc.so.6(+0x7ff4a)[0x7f5820410f4a]
/lib/x86_64-linux-gnu/libc.so.6(cfree+0x4c)[0x7f5820414abc]
/usr/lib/dssi/zynaddsubfx.so(_ZN4Bank9clearbankEv+0xe9)[0x7f57f88b4c29]
/usr/lib/dssi/zynaddsubfx.so(_ZN4Bank8loadbankESs+0x3a)[0x7f57f88b60fa]
/usr/lib/dssi/zynaddsubfx.so(_ZN15DSSIaudiooutput11mapNextBankEv+0x85)[0x7f57f88b3a25]
/usr/lib/dssi/zynaddsubfx.so(_ZN15DSSIaudiooutput10getProgramEm+0x78)[0x7f57f88b3d28]
/usr/lib/lv2/naspro-dssi.lv2/dssi.so(+0x270d)[0x7f58085f770d]
/usr/lib/lv2/naspro-dssi.lv2/dssi.so(+0x213f)[0x7f58085f713f]
/usr/lib/x86_64-linux-gnu/libnabrit.so.3(nabrit_util_load_all_in_dir+0xb5)[0x7f58083f25a5]
/usr/lib/x86_64-linux-gnu/libnabrit.so.3(nabrit_util_load_all_in_env_path+0x84)[0x7f58083f2684]
/usr/lib/lv2/naspro-dssi.lv2/dssi.so(+0x1f40)[0x7f58085f6f40]
/usr/lib/liblilv-0.so.0(lilv_world_load_bundle+0x3f1)[0x7f58230618c1]
/usr/lib/liblilv-0.so.0(+0xebaf)[0x7f5823061baf]
/usr/lib/liblilv-0.so.0(+0xd096)[0x7f5823060096]
/usr/lib/liblilv-0.so.0(+0xd58b)[0x7f582306058b]
/usr/lib/liblilv-0.so.0(lilv_world_load_all+0x137)[0x7f5823061db7]
audacity(_ZN16LV2EffectsModule10InitializeEv+0x77f)[0x978c5f]
audacity(_ZN13ModuleManager18InitializeBuiltinsEv+0x96)[0x66b826]
audacity(_ZN13ModuleManager17DiscoverProvidersEv+0x2b)[0x66c4cb]
audacity(_ZN11AudacityApp6OnInitEv+0x895)[0x5aa4f5]
/usr/lib/x86_64-linux-gnu/libwx_baseu-3.0.so.0(_Z7wxEntryRiPPw+0x92)[0x7f582664ff72]
audacity(main+0x12)[0x537a52]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7f58203b1830]
audacity(_start+0x29)[0x55e8a9]
======= Memory map: ========
00400000-00cce000 r-xp 00000000 08:01 10355184 /usr/bin/audacity
00ece000-00ecf000 r--p 008ce000 08:01 10355184 /usr/bin/audacity
00ecf000-00f5c000 rw-p 008cf000 08:01 10355184 /usr/bin/audacity
00f5c000-00f8d000 rw-p 00000000 00:00 0
02cf7000-04e6e000 rw-p 00000000 00:00 0 [heap]
7f57e8000000-7f57e8053000 rw-p 00000000 00:00 0
7f57e8053000-7f57ec000000 ---p 00000000 00:00 0
7f57f0000000-7f57f0033000 rw-p 00000000 00:00 0
7f57f0033000-7f57f4000000 ---p 00000000 00:00 0
7f57f7456000-7f57f8858000 rw-p 00000000 00:00 0
7f57f8858000-7f57f8b2e000 r-xp 00000000 08:01 14816316 /usr/lib/dssi/zynaddsubfx.so
7f57f8b2e000-7f57f8d2e000 ---p 002d6000 08:01 14816316 /usr/lib/dssi/zynaddsubfx.so
7f57f8d2e000-7f57f8d41000 r--p 002d6000 08:01 14816316 /usr/lib/dssi/zynaddsubfx.so
7f57f8d41000-7f57f8d42000 rw-p 002e9000 08:01 14816316 /usr/lib/dssi/zynaddsubfx.so
7f57f8d42000-7f57f8d43000 rw-p 00000000 00:00 0
7f57f8d43000-7f57f9213000 r-xp 00000000 08:01 14816278 /usr/lib/dssi/linuxsampler.so
7f57f9213000-7f57f9412000 ---p 004d0000 08:01 14816278 /usr/lib/dssi/linuxsampler.so
7f57f9412000-7f57f9440000 r--p 004cf000 08:01 14816278 /usr/lib/dssi/linuxsampler.so
7f57f9440000-7f57f9449000 rw-p 004fd000 08:01 14816278 /usr/lib/dssi/linuxsampler.so
7f57f9449000-7f57f9459000 rw-p 00000000 00:00 0
7f57f9459000-7f57f945e000 r-xp 00000000 08:01 10362634 /usr/lib/x86_64-linux-gnu/libasyncns.so.0.3.1
7f57f945e000-7f57f965d000 ---p 00005000 08:01 10362634 /usr/lib/x86_64-linux-gnu/libasyncns.so.0.3.1
7f57f965d000-7f57f965e000 r--p 00004000 08:01 10362634 /usr/lib/x86_64-linux-gnu/libasyncns.so.0.3.1
7f57f965e000-7f57f965f000 rw-p 00005000 08:01 10362634 /usr/lib/x86_64-linux-gnu/libasyncns.so.0.3.1
7f57f965f000-7f57f9667000 r-xp 00000000 08:01 791066 /lib/x86_64-linux-gnu/libwrap.so.0.7.6
7f57f9667000-7f57f9866000 ---p 00008000 08:01 791066 /lib/x86_64-linux-gnu/libwrap.so.0.7.6
7f57f9866000-7f57f9867000 r--p 00007000 08:01 791066 /lib/x86_64-linux-gnu/libwrap.so.0.7.6
7f57f9867000-7f57f9868000 rw-p 00008000 08:01 791066 /lib/x86_64-linux-gnu/libwrap.so.0.7.6
7f57f9868000-7f57f9869000 rw-p 00000000 00:00 0
7f57f9869000-7f57f9873000 r-xp 00000000 08:01 790939 /lib/x86_64-linux-gnu/libjson-c.so.2.0.0
7f57f9873000-7f57f9a72000 ---p 0000a000 08:01 790939 /lib/x86_64-linux-gnu/libjson-c.so.2.0.0
7f57f9a72000-7f57f9a73000 r--p 00009000 08:01 790939 /lib/x86_64-linux-gnu/libjson-c.so.2.0.0
7f57f9a73000-7f57f9a74000 rw-p 0000a000 08:01 790939 /lib/x86_64-linux-gnu/libjson-c.so.2.0.0
7f57f9a74000-7f57f9a99000 r-xp 00000000 08:01 791052 /lib/x86_64-linux-gnu/libtinfo.so.5.9
7f57f9a99000-7f57f9c98000 ---p 00025000 08:01 791052 /lib/x86_64-linux-gnu/libtinfo.so.5.9
7f57f9c98000-7f57f9c9c000 r--p 00024000 08:01 791052 /lib/x86_64-linux-gnu/libtinfo.so.5.9
7f57f9c9c000-7f57f9c9d000 rw-p 00028000 08:01 791052 /lib/x86_64-linux-gnu/libtinfo.so.5.9
7f57f9c9d000-7f57f9d16000 r-xp 00000000 08:01 10619856 /usr/lib/x86_64-linux-gnu/pulseaudio/libpulsecommon-8.0.so
7f57f9d16000-7f57f9f15000 ---p 00079000 08:01 10619856 /usr/lib/x86_64-linux-gnu/pulseaudio/libpulsecommon-8.0.so
7f57f9f15000-7f57f9f16000 r--p 00078000 08:01 10619856 /usr/lib/x86_64-linux-gnu/pulseaudio/libpulsecommon-8.0.so
7f57f9f16000-7f57f9f17000 rw-p 00079000 08:01 10619856 /usr/lib/x86_64-linux-gnu/pulseaudio/libpulsecommon-8.0.so
7f57f9f17000-7f57f9f65000 r-xp 00000000 08:01 10363529 /usr/lib/x86_64-linux-gnu/libpulse.so.0.19.0
7f57f9f65000-7f57fa164000 ---p 0004e000 08:01 10363529 /usr/lib/x86_64-linux-gnu/libpulse.so.0.19.0
7f57fa164000-7f57fa165000 r--p 0004d000 08:01 10363529 /usr/lib/x86_64-linux-gnu/libpulse.so.0.19.0
7f57fa165000-7f57fa166000 rw-p 0004e000 08:01 10363529 /usr/lib/x86_64-linux-gnu/libpulse.so.0.19.0
7f57fa166000-7f57fa1a3000 r-xp 00000000 08:01 791031 /lib/x86_64-linux-gnu/libreadline.so.6.3
7f57fa1a3000-7f57fa3a3000 ---p 0003d000 08:01 791031 /lib/x86_64-linux-gnu/libreadline.so.6.3
7f57fa3a3000-7f57fa3a5000 r--p 0003d000 08:01 791031 /lib/x86_64-linux-gnu/libreadline.so.6.3
7f57fa3a5000-7f57fa3ab000 rw-p 0003f000 08:01 791031 /lib/x86_64-linux-gnu/libreadline.so.6.3
7f57fa3ab000-7f57fa3ac000 rw-p 00000000 00:00 0
7f57fa3ac000-7f57fa3af000 r-xp 00000000 08:01 10363527 /usr/lib/x86_64-linux-gnu/libpulse-simple.so.0.1.0
7f57fa3af000-7f57fa5af000 ---p 00003000 08:01 10363527 /usr/lib/x86_64-linux-gnu/libpulse-simple.so.0.1.0
7f57fa5af000-7f57fa5b0000 r--p 00003000 08:01 10363527 /usr/lib/x86_64-linux-gnu/libpulse-simple.so.0.1.0
7f57fa5b0000-7f57fa5b1000 rw-p 00004000 08:01 10363527 /usr/lib/x86_64-linux-gnu/libpulse-simple.so.0.1.0
7f57fa5b1000-7f57fa606000 r-xp 00000000 08:01 10360539 /usr/lib/x86_64-linux-gnu/libfluidsynth.so.1.5.2
7f57fa606000-7f57fa806000 ---p 00055000 08:01 10360539 /usr/lib/x86_64-linux-gnu/libfluidsynth.so.1.5.2
7f57fa806000-7f57fa807000 r--p 00055000 08:01 10360539 /usr/lib/x86_64-linux-gnu/libfluidsynth.so.1.5.2
7f57fa807000-7f57fa809000 rw-p 00056000 08:01 10360539 /usr/lib/x86_64-linux-gnu/libfluidsynth.so.1.5.2
7f57fa809000-7f57fa877000 rw-p 00000000 00:00 0
7f57fa877000-7f57fa87c000 r-xp 00000000 08:01 14811437 /usr/lib/dssi/fluidsynth-dssi.so
7f57fa87c000-7f57faa7b000 ---p 00005000 08:01 14811437 /usr/lib/dssi/fluidsynth-dssi.so
7f57faa7b000-7f57faa7c000 r--p 00004000 08:01 14811437 /usr/lib/dssi/fluidsynth-dssi.so
7f57faa7c000-7f57faa7d000 rw-p 00005000 08:01 14811437 /usr/lib/dssi/fluidsynth-dssi.so
7f57faa7d000-7f57faa80000 r-xp 00000000 08:01 14819975 /usr/lib/dssi/ll-scope.so
7f57faa80000-7f57fac7f000 ---p 00003000 08:01 14819975 /usr/lib/dssi/ll-scope.so
7f57fac7f000-7f57fac80000 r--p 00002000 08:01 14819975 /usr/lib/dssi/ll-scope.so
7f57fac80000-7f57fac81000 rw-p 00003000 08:01 14819975 /usr/lib/dssi/ll-scope.so
7f57fac81000-7f57fac82000 ---p 00000000 00:00 0
7f57fac82000-7f57fb482000 rw-p 00000000 00:00 0
7f57fb657000-7f57fb7fc000 r-xp 00000000 08:01 14814055 /usr/lib/dssi/whysynth.so
7f57fb7fc000-7f57fb9fc000 ---p 001a5000 08:01 14814055 /usr/lib/dssi/whysynth.so
7f57fb9fc000-7f57fba08000 r--p 001a5000 08:01 14814055 /usr/lib/dssi/whysynth.so
7f57fba08000-7f57fbbd0000 rw-p 001b1000 08:01 14814055 /usr/lib/dssi/whysynth.so
7f57fbbd0000-7f57fbbd1000 rw-p 00000000 00:00 0
7f57fbbd1000-7f57fbbd7000 r-xp 00000000 08:01 14819969 /usr/lib/dssi/horgand.so
7f57fbbd7000-7f57fbdd7000 ---p 00006000 08:01 14819969 /usr/lib/dssi/horgand.so
7f57fbdd7000-7f57fbdd8000 r--p 00006000 08:01 14819969 /usr/lib/dssi/horgand.so
7f57fbdd8000-7f57fbdd9000 rw-p 00007000 08:01 14819969 /usr/lib/dssi/horgand.so
7f57fbdd9000-7f57fbdfb000 r-xp 00000000 08:01 14815675 /usr/lib/dssi/dssi-vst.so
7f57fbdfb000-7f57fbffb000 ---p 00022000 08:01 14815675 /usr/lib/dssi/dssi-vst.so
7f57fbffb000-7f57fbffc000 r--p 00022000 08:01 14815675 /usr/lib/dssi/dssi-vst.so
7f57fbffc000-7f57fbffd000 rw-p 00023000 08:01 14815675 /usr/lib/dssi/dssi-vst.so
7f57fbffd000-7f57fc000000 rw-p 00000000 00:00 0
7f57fc000000-7f57fc021000 rw-p 00000000 00:00 0
7f57fc021000-7f5800000000 ---p 00000000 00:00 0
7f5800000000-7f5800022000 rw-p 00000000 00:00 0
7f5800022000-7f5804000000 ---p 00000000 00:00 0
7f5804000000-7f5804021000 rw-p 00000000 00:00 0
7f5804021000-7f5808000000 ---p 00000000 00:00 0
7f58081e1000-7f58081ee000 r-xp 00000000 08:01 10367850 /usr/lib/x86_64-linux-gnu/libnacore.so.5.0.2
7f58081ee000-7f58083ed000 ---p 0000d000 08:01 10367850 /usr/lib/x86_64-linux-gnu/libnacore.so.5.0.2
7f58083ed000-7f58083ee000 r--p 0000c000 08:01 10367850 /usr/lib/x86_64-linux-gnu/libnacore.so.5.0.2
7f58083ee000-7f58083ef000 rw-p 0000d000 08:01 10367850 /usr/lib/x86_64-linux-gnu/libnacore.so.5.0.2
7f58083ef000-7f58083f4000 r-xp 00000000 08:01 10367852 /usr/lib/x86_64-linux-gnu/libnabrit.so.3.0.0
7f58083f4000-7f58085f3000 ---p 00005000 08:01 10367852 /usr/lib/x86_64-linux-gnu/libnabrit.so.3.0.0
7f58085f3000-7f58085f4000 r--p 00004000 08:01 10367852 /usr/lib/x86_64-linux-gnu/libnabrit.so.3.0.0
7f58085f4000-7f58085f5000 rw-p 00005000 08:01 10367852 /usr/lib/x86_64-linux-gnu/libnabrit.so.3.0.0
7f58085f5000-7f58085f9000 r-xp 00000000 08:01 14158307 /usr/lib/lv2/naspro-dssi.lv2/dssi.so
7f58085f9000-7f58087f8000 ---p 00004000 08:01 14158307 /usr/lib/lv2/naspro-dssi.lv2/dssi.so
7f58087f8000-7f58087f9000 r--p 00003000 08:01 14158307 /usr/lib/lv2/naspro-dssi.lv2/dssi.so
7f58087f9000-7f58087fa000 rw-p 00004000 08:01 14158307 /usr/lib/lv2/naspro-dssi.lv2/dssi.so
7f58087fa000-7f5808822000 rw-p 00000000 00:00 0
7f580898a000-7f5808994000 r-xp 00000000 08:01 10749105 /usr/lib/x86_64-linux-gnu/gtk-2.0/2.10.0/engines/libpixmap.so
7f5808994000-7f5808b93000 ---p 0000a000 08:01 10749105 /usr/lib/x86_64-linux-gnu/gtk-2.0/2.10.0/engines/libpixmap.so
7f5808b93000-7f5808b94000 r--p 00009000 08:01 10749105 /usr/lib/x86_64-linux-gnu/gtk-2.0/2.10.0/engines/libpixmap.so
7f5808b94000-7f5808b95000 rw-p 0000a000 08:01 10749105 /usr/lib/x86_64-linux-gnu/gtk-2.0/2.10.0/engines/libpixmap.so
7f5808b95000-7f5808bc5000 r-xp 00000000 08:01 10748526 /usr/lib/x86_64-linux-gnu/gtk-2.0/2.10.0/engines/libmurrine.so
7f5808bc5000-7f5808dc5000 ---p 00030000 08:01 10748526 /usr/lib/x86_64-linux-gnu/gtk-2.0/2.10.0/engines/libmurrine.so
7f5808dc5000-7f5808dc6000 r--p 00030000 08:01 10748526 /usr/lib/x86_64-linux-gnu/gtk-2.0/2.10.0/engines/libmurrine.so
7f5808dc6000-7f5808dc7000 rw-p 00031000 08:01 10748526 /usr/lib/x86_64-linux-gnu/gtk-2.0/2.10.0/engines/libmurrine.so
7f5808dc7000-7f5808dc8000 ---p 00000000 00:00 0
7f5808dc8000-7f58095c8000 rw-p 00000000 00:00 0
7f58095c8000-7f58095c9000 ---p 00000000 00:00 0
7f58095c9000-7f5809dc9000 rw-p 00000000 00:00 0
7f5809dc9000-7f5809dca000 ---p 00000000 00:00 0
7f5809dca000-7f580a5ca000 rw-p 00000000 00:00 0
7f580a5ca000-7f580a5d5000 r-xp 00000000 08:01 10748610 /usr/lib/x86_64-linux-gnu/gio/modules/libdconfsettings.so
7f580a5d5000-7f580a7d5000 ---p 0000b000 08:01 10748610 /usr/lib/x86_64-linux-gnu/gio/modules/libdconfsettings.so
7f580a7d5000-7f580a7d6000 r--p 0000b000 08:01 10748610 /usr/lib/x86_64-linux-gnu/gio/modules/libdconfsettings.so
7f580a7d6000-7f580a7d7000 rw-p 0000c000 08:01 10748610 /usr/lib/x86_64-linux-gnu/gio/modules/libdconfsettings.so
7f580a7d7000-7f580a803000 r-xp 00000000 08:01 10362644 /usr/lib/x86_64-linux-gnu/libatspi.so.0.0.1
7f580a803000-7f580aa02000 ---p 0002c000 08:01 10362644 /usr/lib/x86_64-linux-gnu/libatspi.so.0.0.1
7f580aa02000-7f580aa05000 r--p 0002b000 08:01 10362644 /usr/lib/x86_64-linux-gnu/libatspi.so.0.0.1
7f580aa05000-7f580aa06000 rw-p 0002e000 08:01 10362644 /usr/lib/x86_64-linux-gnu/libatspi.so.0.0.1
7f580aa06000-7f580aa33000 r-xp 00000000 08:01 10362638 /usr/lib/x86_64-linux-gnu/libatk-bridge-2.0.so.0.0.0
7f580aa33000-7f580ac32000 ---p 0002d000 08:01 10362638 /usr/lib/x86_64-linux-gnu/libatk-bridge-2.0.so.0.0.0
7f580ac32000-7f580ac33000 r--p 0002c000 08:01 10362638 /usr/lib/x86_64-linux-gnu/libatk-bridge-2.0.so.0.0.0
7f580ac33000-7f580ac35000 rw-p 0002d000 08:01 10362638 /usr/lib/x86_64-linux-gnu/libatk-bridge-2.0.so.0.0.0
7f580ac35000-7f580ac36000 r-xp 00000000 08:01 10748642 /usr/lib/x86_64-linux-gnu/gtk-2.0/modules/libatk-bridge.so
7f580ac36000-7f580ae35000 ---p 00001000 08:01 10748642 /usr/lib/x86_64-linux-gnu/gtk-2.0/modules/libatk-bridge.so
7f580ae35000-7f580ae36000 r--p 00000000 08:01 10748642 /usr/lib/x86_64-linux-gnu/gtk-2.0/modules/libatk-bridge.so
7f580ae36000-7f580ae37000 rw-p 00001000 08:01 10748642 /usr/lib/x86_64-linux-gnu/gtk-2.0/modules/libatk-bridge.so
7f580ae37000-7f580ae85000 r-xp 00000000 08:01 10748645 /usr/lib/x86_64-linux-gnu/gtk-2.0/modules/libgail.so
7f580ae85000-7f580b084000 ---p 0004e000 08:01 10748645 /usr/lib/x86_64-linux-gnu/gtk-2.0/modules/libgail.so
7f580b084000-7f580b085000 r--p 0004d000 08:01 10748645 /usr/lib/x86_64-linux-gnu/gtk-2.0/modules/libgail.so
7f580b085000-7f580b087000 rw-p 0004e000 08:01 10748645 /usr/lib/x86_64-linux-gnu/gtk-2.0/modules/libgail.so
7f580b087000-7f580b098000 r-xp 00000000 08:01 10748646 /usr/lib/x86_64-linux-gnu/gtk-2.0/modules/liboverlay-scrollbar.so
7f580b098000-7f580b298000 ---p 00011000 08:01 10748646 /usr/lib/x86_64-linux-gnu/gtk-2.0/modules/liboverlay-scrollbar.so
7f580b298000-7f580b299000 r--p 00011000 08:01 10748646 /usr/lib/x86_64-linux-gnu/gtk-2.0/modules/liboverlay-scrollbar.so
7f580b299000-7f580b29a000 rw-p 00012000 08:01 10748646 /usr/lib/x86_64-linux-gnu/gtk-2.0/modules/liboverlay-scrollbar.so
7f580b29a000-7f580b2a5000 r-xp 00000000 08:01 790979 /lib/x86_64-linux-gnu/libnss_files-2.23.so
7f580b2a5000-7f580b4a4000 ---p 0000b000 08:01 790979 /lib/x86_64-linux-gnu/libnss_files-2.23.so
7f580b4a4000-7f580b4a5000 r--p 0000a000 08:01 790979 /lib/x86_64-linux-gnu/libnss_files-2.23.so
7f580b4a5000-7f580b4a6000 rw-p 0000b000 08:01 790979 /lib/x86_64-linux-gnu/libnss_files-2.23.so
7f580b4a6000-7f580b4ac000 rw-p 00000000 00:00 0
7f580b4ac000-7f580b4b7000 r-xp 00000000 08:01 790989 /lib/x86_64-linux-gnu/libnss_nis-2.23.so
7f580b4b7000-7f580b6b6000 ---p 0000b000 08:01 790989 /lib/x86_64-linux-gnu/libnss_nis-2.23.so
7f580b6b6000-7f580b6b7000 r--p 0000a000 08:01 790989 /lib/x86_64-linux-gnu/libnss_nis-2.23.so
7f580b6b7000-7f580b6b8000 rw-p 0000b000 08:01 790989 /lib/x86_64-linux-gnu/libnss_nis-2.23.so
7f580b6b8000-7f580b6ce000 r-xp 00000000 08:01 790973 /lib/x86_64-linux-gnu/libnsl-2.23.so
7f580b6ce000-7f580b8cd000 ---p 00016000 08:01 790973 /lib/x86_64-linux-gnu/libnsl-2.23.so
7f580b8cd000-7f580b8ce000 r--p 00015000 08:01 790973 /lib/x86_64-linux-gnu/libnsl-2.23.so
7f580b8ce000-7f580b8cf000 rw-p 00016000 08:01 790973 /lib/x86_64-linux-gnu/libnsl-2.23.so
7f580b8cf000-7f580b8d1000 rw-p 00000000 00:00 0
7f580b8d1000-7f580b8d9000 r-xp 00000000 08:01 790975 /lib/x86_64-linux-gnu/libnss_compat-2.23.so
7f580b8d9000-7f580bad8000 ---p 00008000 08:01 790975 /lib/x86_64-linux-gnu/libnss_compat-2.23.so
7f580bad8000-7f580bad9000 r--p 00007000 08:01 790975 /lib/x86_64-linux-gnu/libnss_compat-2.23.so
7f580bad9000-7f580bada000 rw-p 00008000 08:01 790975 /lib/x86_64-linux-gnu/libnss_compat-2.23.so
7f580bada000-7f580bae3000 r-xp 00000000 08:01 10363305 /usr/lib/x86_64-linux-gnu/libltdl.so.7.3.1
7f580bae3000-7f580bce2000 ---p 00009000 08:01 10363305 /usr/lib/x86_64-linux-gnu/libltdl.so.7.3.1
7f580bce2000-7f580bce3000 r--p 00008000 08:01 10363305 /usr/lib/x86_64-linux-gnu/libltdl.so.7.3.1
7f580bce3000-7f580bce4000 rw-p 00009000 08:01 10363305 /usr/lib/x86_64-linux-gnu/libltdl.so.7.3.1
7f580bce4000-7f580bcf8000 r-xp 00000000 08:01 10363680 /usr/lib/x86_64-linux-gnu/libtdb.so.1.3.8
7f580bcf8000-7f580bef7000 ---p 00014000 08:01 10363680 /usr/lib/x86_64-linux-gnu/libtdb.so.1.3.8
7f580bef7000-7f580bef8000 r--p 00013000 08:01 10363680 /usr/lib/x86_64-linux-gnu/libtdb.so.1.3.8
7f580bef8000-7f580bef9000 rw-p 00014000 08:01 10363680 /usr/lib/x86_64-linux-gnu/libtdb.so.1.3.8
7f580bef9000-7f580befe000 r-xp 00000000 08:01 10357543 /usr/lib/x86_64-linux-gnu/libORBitCosNaming-2.so.0.1.0
7f580befe000-7f580c0fe000 ---p 00005000 08:01 10357543 /usr/lib/x86_64-linux-gnu/libORBitCosNaming-2.so.0.1.0
7f580c0fe000-7f580c0ff000 r--p 00005000 08:01 10357543 /usr/lib/x86_64-linux-gnu/libORBitCosNaming-2.so.0.1.0
7f580c0ff000-7f580c100000 rw-p 00006000 08:01 10357543 /usr/lib/x86_64-linux-gnu/libORBitCosNaming-2.so.0.1.0
7f580c100000-7f580c102000 r-xp 00000000 08:01 791061 /lib/x86_64-linux-gnu/libutil-2.23.so
7f580c102000-7f580c301000 ---p 00002000 08:01 791061 /lib/x86_64-linux-gnu/libutil-2.23.so
7f580c301000-7f580c302000 r--p 00001000 08:01 791061 /lib/x86_64-linux-gnu/libutil-2.23.so
7f580c302000-7f580c303000 rw-p 00002000 08:01 791061 /lib/x86_64-linux-gnu/libutil-2.23.so
7f580c303000-7f580c313000 r-xp 00000000 08:01 10362648 /usr/lib/x86_64-linux-gnu/libavahi-client.so.3.2.9
7f580c313000-7f580c512000 ---p 00010000 08:01 10362648 /usr/lib/x86_64-linux-gnu/libavahi-client.so.3.2.9
7f580c512000-7f580c513000 r--p 0000f000 08:01 10362648 /usr/lib/x86_64-linux-gnu/libavahi-client.so.3.2.9
7f580c513000-7f580c514000 rw-p 00010000 08:01 10362648 /usr/lib/x86_64-linux-gnu/libavahi-client.so.3.2.9
7f580c514000-7f580c51f000 r-xp 00000000 08:01 10362650 /usr/lib/x86_64-linux-gnu/libavahi-common.so.3.5.3
7f580c51f000-7f580c71e000 ---p 0000b000 08:01 10362650 /usr/lib/x86_64-linux-gnu/libavahi-common.so.3.5.3
7f580c71e000-7f580c71f000 r--p 0000a000 08:01 10362650 /usr/lib/x86_64-linux-gnu/libavahi-common.so.3.5.3
7f580c71f000-7f580c720000 rw-p 0000b000 08:01 10362650 /usr/lib/x86_64-linux-gnu/libavahi-common.so.3.5.3
7f580c720000-7f580c723000 r-xp 00000000 08:01 10362654 /usr/lib/x86_64-linux-gnu/libavahi-glib.so.1.0.2
7f580c723000-7f580c922000 ---p 00003000 08:01 10362654 /usr/lib/x86_64-linux-gnu/libavahi-glib.so.1.0.2
7f580c922000-7f580c923000 r--p 00002000 08:01 10362654 /usr/lib/x86_64-linux-gnu/libavahi-glib.so.1.0.2
7f580c923000-7f580c924000 rw-p 00003000 08:01 10362654 /usr/lib/x86_64-linux-gnu/libavahi-glib.so.1.0.2
7f580c924000-7f580c949000 r-xp 00000000 08:01 10362788 /usr/lib/x86_64-linux-gnu/libdbus-glib-1.so.2.3.3
7f580c949000-7f580cb49000 ---p 00025000 08:01 10362788 /usr/lib/x86_64-linux-gnu/libdbus-glib-1.so.2.3.3
7f580cb49000-7f580cb4a000 r--p 00025000 08:01 10362788 /usr/lib/x86_64-linux-gnu/libdbus-glib-1.so.2.3.3
7f580cb4a000-7f580cb4b000 rw-p 00026000 08:01 10362788 /usr/lib/x86_64-linux-gnu/libdbus-glib-1.so.2.3.3
7f580cb4b000-7f580cb5b000 r-xp 00000000 08:01 10362702 /usr/lib/x86_64-linux-gnu/libcanberra.so.0.2.5
7f580cb5b000-7f580cd5a000 ---p 00010000 08:01 10362702 /usr/lib/x86_64-linux-gnu/libcanberra.so.0.2.5
7f580cd5a000-7f580cd5b000 r--p 0000f000 08:01 10362702 /usr/lib/x86_64-linux-gnu/libcanberra.so.0.2.5
7f580cd5b000-7f580cd5c000 rw-p 00010000 08:01 10362702 /usr/lib/x86_64-linux-gnu/libcanberra.so.0.2.5
7f580cd5c000-7f580cd5d000 r-xp 00000000 08:01 10355082 /usr/lib/x86_64-linux-gnu/libgthread-2.0.so.0.4800.1
7f580cd5d000-7f580cf5c000 ---p 00001000 08:01 10355082 /usr/lib/x86_64-linux-gnu/libgthread-2.0.so.0.4800.1
7f580cf5c000-7f580cf5d000 r--p 00000000 08:01 10355082 /usr/lib/x86_64-linux-gnu/libgthread-2.0.so.0.4800.1Aborted (core dumped)brian
- Quality Assurance
Reinstalling what? What version of Audacity are you running now and where exactly did you obtain it?briandc wrote:I tried re-installing
What does "About This Computer" say about your operating system?
My suggestion was that you install the actual KXStudio distribution based on Ubuntu 14.04 (which I assume will give you an older version of Audacity), or uninstall KXStudio and see if Audacity runs after rebooting the machine. If in doubt, ask KXStudio for help, given the problem started with them.
