I just googled how to install audacity on ubuntu 14.04 and followed the instructions to add this ppa: audacity-team-daily-trusty.list
Apologies if it's not recommended to install a daily alpha, but it's what I found googling. If the solution to the crash is to install something stabler, please advise how.
What I did:
1. ran Audacity v2.1.3-alpha-Jun 9 2016 on Ubuntu 14.04
2. imported a two-minute mp3
3. copied a solo section I wanted, about 20 seconds of audio
4. originally I tried File->New, following a youtube tutorial I found, to paste the solo section, and Audacity crashed.
5. I ran Audacity from the command line
6. It seems to be able to recover my work *at this point*
7. I tried saving the project. Audacity crashed.
The output:
Code: Select all
$ audacity
(process:7101): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::sm-connect after class was initialised
(process:7101): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::show-crash-dialog after class was initialised
(process:7101): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::display after class was initialised
(process:7101): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::default-icon after class was initialised
(Audacity:7101): Gtk-WARNING **: gtk_disable_setlocale() must be called before gtk_init()
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
bt_audio_service_open: connect() failed: Connection refused (111)
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
Expression 'stream->playback.pcm' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 4611
Expression 'ret' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1736
Expression 'AlsaOpen( &alsaApi->baseHostApiRep, params, streamDir, &self->pcm )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1904
Expression 'PaAlsaStreamComponent_Initialize( &self->capture, alsaApi, inParams, StreamDirection_In, NULL != callback )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2171
Expression 'PaAlsaStream_Initialize( stream, alsaHostApi, inputParameters, outputParameters, sampleRate, framesPerBuffer, callback, streamFlags, userData )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2840
*** Caught unhandled unknown exception; terminating
10:21:59 PM: Debug: pthread_mutex_[timed]lock(): mutex not initialized
10:21:59 PM: Debug: pthread_mutex_unlock(): mutex not initialized.
