I am a total newbie and I would like any help I can get. If you need anymore information just ask. Cheers!(Audacity:22929): Gtk-CRITICAL **: IA__gtk_widget_get_direction: assertion 'GTK_IS_WIDGET (widget)' failed
wierd error on linux mint
Please state:
Please state:
I get the following error whenever I try to run audacity on Linux mint 17.3 'Rosa' MATE machine.
- Quality Assurance
Re: wierd error on linux mint
Does anything bad happen in Audacity? What version of Audacity are you using (all three numbers) and where did you obtain it from? Please see the pink panel at the top of the page.rvs314 wrote:I get the following error whenever I try to run audacity on Linux mint 17.3 'Rosa' MATE machine.(Audacity:22929): Gtk-CRITICAL **: IA__gtk_widget_get_direction: assertion 'GTK_IS_WIDGET (widget)' failed
