Please state:
Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade (see
https://www.audacityteam.org/download/).
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
- Quality Assurance
Post
by Gale Andrews » Fri May 20, 2016 11:37 am
rick71 wrote:Gale Andrews wrote:Are you using system wxWidgets that uses STL? Audacity will fail to compile with the issues you see in that case.
If you self-build wxWidgets 3.0.2 from
https://github.com/wxWidgets/wxWidgets/ ... .2.tar.bz2 with no configure arguments, install that Widgets build then run ldconfig, Audacity should build fine.
I have no idea if my wxWidgets uses STL. I don't know how to check. I am using the version that is available in the opensuse Leap 42.1
Then that's the answer. It's configured with STL. I have raised a bug report about it yesterday:
http://bugzilla.audacityteam.org/show_bug.cgi?id=1393.
rick71
- Operating System: Linux Debian
Post
by rick71 » Fri May 20, 2016 12:34 pm
Gale Andrews wrote:rick71 wrote:Gale Andrews wrote:Are you using system wxWidgets that uses STL? Audacity will fail to compile with the issues you see in that case.
My apologies.
I am not using the opensuse Leap 42.1 package. I originally used it, and it crashed as described. I then switched to the latest version in the Packman Leap 42.1 repository. I believe the error messages were the same.
davepl
Post
by davepl » Tue Jun 28, 2016 12:53 pm
rick71 wrote:Thanks.
I've left a message on the opensuse multimedia forum. Hopefully the devs will see it and speed up the update.
I maintain and am bugowner of audacity on openSUSE, I'm in the process of submitting wxWidgets-3_0-nostl in order to get the update going. If you had filed a bug at openSUSE it would make the submission easier. Audacity-2.1.2 is available in
http://download.opensuse.org/repositori ... _Leap_42.1 and the wxWidget without stl are in :
http://download.opensuse.org/repositori ... _Leap_42.1 both need to be enabled. Version 2.1.2 is also in Packman but I'm waiting for them to link wxWidgets.
Maybe the best place to install audacity-2.1.2 ATM is :
http://pmbs-api.links2linux.org:8080/ho ... Leap_42.1/
Substitute "openSUSE_Tumbleweed" for Tumbleweed,
Please open a bug at :
https://bugzilla.opensuse.org it will make my life easier.
I stumbled on this thread searching for an earlier thread where the user had built there own wxWidgets and audacity on openSUSE to use as ammunition to get my wx package into factory.
Dave
