Problem accessing the mic with 2.1.1 with Azalia sound card
Please state:
tgf
Operating System: Linux Debian
Re: Problem accessing the mic with 2.1.1 with Azalia sound c
Post by tgf » Mon Mar 28, 2016 11:06 pm
I first checked with "ps -eaf | grep pulse" that pulseaudio was running
Code: Select all
gfreeman  1842     1  0 Mar24 ?        00:02:28 /usr/bin/pulseaudio --start --log-target=syslog
I then ran pavucontrol and connected the sound source to the Mic port, confirming that pavucontrol could see the signal.
With pavucontrol on Recording, I issued the command "arecord -d 4 /tmp/test.wav". Pavucontrol window changed from
Code: Select all
No application is currently recording audio
to
Code: Select all
ALSA plugin [aplay]: ALSA Capture from [Built-in Audio Analog Stereo]
and below the arecord command was the message
Code: Select all
Recording WAVE '/tmp/test.wav' : Unsigned 8 bit, Rate 8000 Hz, Mono
Post by steve » Tue Mar 29, 2016 11:11 am
tgf wrote:
Code: Select all
That could be the problem.
I'm not certain, but I think that Audacity expects / requires the audio sample format to be at least 16 bit.
This article gives a general idea of how to change the default format for PulseAudio: http://www.overclock.net/a/how-to-get-t ... pulseaudio
I'd suggest that you try setting the default format to signed 16-bit, and a sample rate of 44100 Hz.
This is what I have:
Code: Select all
default-sample-format = s16le
default-sample-rate = 44100
alternate-sample-rate = 48000
default-sample-channels = 2
default-channel-map = front-left,front-right
You will need to at least restart Pulse - I'd suggest logging out and back in again, or rebooting to ensure that the changes take effect.
(Leave Audacity preferences at the default "32-bit float" 44100 Hz.)
BE SURE TO MAKE THE BACKUP.
If the above does not work, there is a much more in-depth article on the subject here: https://wiki.archlinux.org/index.php/Pu ... figuration
tgf
Post by tgf » Wed Mar 30, 2016 3:35 am
Steve wrote
...This article gives a general idea of how to change the default format for PulseAudio: http://www.overclock.net/a/how-to-get-t ... pulseaudio
I don't think that is the problem. "arecord" has 8000 Hz and unsigned 8 bit as the defaults. I can change them with
Code: Select all
arecord -d 4 -r 192 -f cd /tmp/test.wav
I did look at /etc/pulse/daemon.conf as you suggested. It indicated that
Code: Select all
were the defaults. I uncommented those lines and re-logged in, but it has made no difference.
Now, I am seeing "default" as the only selectable input.
Post by steve » Wed Mar 30, 2016 10:14 am
I'm running out of ideas.
Look in "Help > About Audacity > Build Information". Which version of PortAudio and wxWidgets has Audacity been built with?
Post by Gale Andrews » Wed Mar 30, 2016 4:14 pm
Perhaps tgf should build current Audacity from source code http://www.audacityteam.org/download/source/. We recently updated PortAudio which has a lot of fixes for Linux.
tgf
Post by tgf » Fri Apr 01, 2016 5:19 am
Build information -> Core libraries indicates:
Code: Select all
PortAudio   (Audio playback and recording)   v19
wxWidgets 2.8.12
I have downloaded the source code, and installed all the "-dev" packages that I thought would help. I have run "./configure" and then "make" but compilation is failing because of data type issues:
Code: Select all
mv -f .deps/audacity-BlockFile.Tpo .deps/audacity-BlockFile.Po
g++ -DHAVE_CONFIG_H -I.  -Wno-deprecated-declarations -D__STDC_CONSTANT_MACROS -DLIBDIR=\"/usr/local//lib64\"   -I../lib-src/portaudio-v19/include   -I../lib-src/libsoxr/src -I../lib-src/lib-widget-extra -I/usr/lib64/wx/include/gtk3-unicode-3.0 -I/usr/include/wx-3.0 -D_FILE_OFFSET_BITS=64 -DwxDEBUG_LEVEL=0 -DWXUSINGDLL -D__WXGTK__ -pthread   -I../lib-src/ffmpeg   -I../lib-src/lame    -I../lib-src/libnyquist    -I../lib-src/lv2/include -I../lib-src/lv2/include -I../lib-src/portsmf  -I../lib-src/sbsms/include -I../lib-src/libvamp  -I/usr/lib64/wx/include/gtk3-unicode-3.0 -I/usr/include/wx-3.0 -D_FILE_OFFSET_BITS=64 -DwxDEBUG_LEVEL=0 -DWXUSINGDLL -D__WXGTK__ -pthread -pthread -I/usr/include/gtk-3.0 -I/usr/include/at-spi2-atk/2.0 -I/usr/include/at-spi-2.0 -I/usr/include/dbus-1.0 -I/usr/lib64/dbus-1.0/include -I/usr/include/gtk-3.0 -I/usr/include/gio-unix-2.0/ -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/harfbuzz -I/usr/include/pango-1.0 -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pixman-1 -I/usr/include/freetype2 -I/usr/include/libdrm -I/usr/include/libpng16 -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/libpng16 -I/usr/include/glib-2.0 -I/usr/lib64/glib-2.0/include  -Wno-unused-local-typedefs -I../lib-src/portmixer/include  -DwxDEBUG_LEVEL=0  -Wall -I../include -I../lib-src/FileDialog                 -MT audacity-DirManager.o -MD -MP -MF .deps/audacity-DirManager.Tpo -c -o audacity-DirManager.o `test -f 'DirManager.cpp' || echo './'`DirManager.cpp
In file included from /usr/include/wx-3.0/wx/intl.h:17:0,
                 from /usr/include/wx-3.0/wx/filename.h:17,
                 from DirManager.h:16,
                 from DirManager.cpp:65:
blockfile/../ondemand/ODDecodeTask.h: In member function ‘virtual const wxChar* ODDecodeTask::GetTip()’:
/usr/include/wx-3.0/wx/translation.h:38:58: error: cannot convert ‘const wxString’ to ‘const wxChar* {aka const wchar_t*}’ in return
     #define _(s)                     wxGetTranslation((s))
blockfile/../ondemand/ODDecodeTask.h:57:42: note: in expansion of macro ‘_’
    virtual const wxChar* GetTip(){return _("Decoding Waveform");}
DirManager.cpp: In static member function ‘static void DirManager::CleanTempDir()’:
DirManager.cpp:397:88: error: cannot convert ‘const wxString’ to ‘const wxChar* {aka const wchar_t*}’ for argument ‘5’ to ‘void RecursivelyRemove(wxArrayString&, int, bool, bool, const wxChar*)’
    RecursivelyRemove(filePathArray, count, true, true, _("Cleaning up temporary files"));
DirManager.cpp: In member function ‘bool DirManager::SetProject(wxString&, wxString&, bool)’:
DirManager.cpp:523:91: error: cannot convert ‘const wxString’ to ‘const wxChar* {aka const wchar_t*}’ for argument ‘5’ to ‘void RecursivelyRemove(wxArrayString&, int, bool, bool, const wxChar*)’
          RecursivelyRemove(dirlist, count, false, true, _("Cleaning up cache directories"));
DirManager.cpp: In member function ‘wxFileName DirManager::MakeBlockFilePath(wxString)’:
DirManager.cpp:592:9: warning: suggest explicit braces to avoid ambiguous ‘else’ [-Wparentheses]
       if(!dir.DirExists() && !dir.Mkdir(0777,wxPATH_MKDIR_FULL))
DirManager.cpp: In member function ‘int DirManager::ProjectFSCK(bool, bool)’:
DirManager.cpp:1395:17: error: cannot convert ‘const wxString’ to ‘const wxChar* {aka const wchar_t*}’ in initialization
             NULL};
DirManager.cpp:1412:40: error: cannot convert ‘const wxString’ to ‘const wxChar* {aka const wchar_t*}’ for argument ‘7’ to ‘int RecursivelyEnumerateWithProgress(wxString, wxArrayString&, wxString, bool, bool, int, const wxChar*)’
       _("Inspecting project file data"));
DirManager.cpp:1449:20: error: cannot convert ‘const wxString’ to ‘const wxChar* {aka const wchar_t*}’ in initialization
                NULL};
DirManager.cpp:1511:41: error: cannot convert ‘const wxString’ to ‘const wxChar* {aka const wchar_t*}’ in initialization
                                     NULL};
DirManager.cpp:1570:20: error: cannot convert ‘const wxString’ to ‘const wxChar* {aka const wchar_t*}’ in initialization
                NULL};
DirManager.cpp:1629:17: error: cannot convert ‘const wxString’ to ‘const wxChar* {aka const wchar_t*}’ in initialization
             NULL};
DirManager.cpp: In member function ‘void DirManager::RemoveOrphanBlockfiles()’:
DirManager.cpp:1817:40: error: cannot convert ‘const wxString’ to ‘const wxChar* {aka const wchar_t*}’ for argument ‘7’ to ‘int RecursivelyEnumerateWithProgress(wxString, wxArrayString&, wxString, bool, bool, int, const wxChar*)’
Makefile:2407: recipe for target 'audacity-DirManager.o' failed
make[2]: *** [audacity-DirManager.o] Error 1
make[2]: Leaving directory '/tmp/audacity-minsrc-2.1.2/src'
Makefile:1346: recipe for target 'all' failed
make[1]: *** [all] Error 2
make[1]: Leaving directory '/tmp/audacity-minsrc-2.1.2/src'
Makefile:716: recipe for target 'all-recursive' failed
make: *** [all-recursive] Error 1
Post by Gale Andrews » Fri Apr 01, 2016 12:36 pm
Are you using system wxWidgets? Audacity will fail to compile with the issues you see in that case, because system wxWidgets on OpenSUSE uses STL.
If you self-build wxWidgets with no configure arguments I would assume Audacity will build against it.
Code: Select all
             NULL};
                NULL};
                                     NULL};
                NULL};
             NULL};
Post by steve » Fri Apr 01, 2016 12:50 pm
tgf wrote: I have run "./configure" and then "make" but compilation is failing because of data type issues:
I think this may be fixed in jengelh's fork:
https://github.com/jengelh/audacity
Unfortunately the pull request from jengelh has merge conflicts with the current audacity/audacity code, but if you can confirm that jengelh's fix works, then that may help to get the fix committed.
Post by Gale Andrews » Fri Apr 01, 2016 2:01 pm
ThomasFeher has already confirmed that commit fixes building on OpenSUSE https://github.com/audacity/audacity/pull/112 but Paul did not want to commit it even if he resolved the conflicts.
If no-one reviews and commits we'll have to track it on Audacity Bugzilla.
